> 914 and 550, both T4, One Cold Starts, the Other Doesn't, Why?
Tastyplacement
post Jun 24 2017, 08:11 PM
This is baffling to me. I have two type 4 cars, both have 914 motors and have a lot off commonality to them. My 914 starts cold no problem. My 550 replica is a total hassle to start cold.
The 914 which cold starts very easily:
-1.8 liter motor
-twin IDF 40 with no choke and no cold start circuit
Main Jets are 115
Idle Jets are 55
carbs were recently completely rebuilt
-Pertronix Ingnitor 1 points replacement
The 550 replica:
-2.3 liter motor
Main jets are 155
Idle jets are 65
carbs seem great, but haven't been thoroughly cleaned recently
-twin IDF 44 with no choke and no cold start circuit
-Pertronix Ignitor 3 points replacement
The 914, I pump the pedal once, car starts every time and is immediately steady. The 550, I have to pump the pedal 4 or 5 times and It'll fire quickly and die quickly. Once I do this a few times it'll run if I keep it at about 2000rpm by feathering throttle. Once it is warm, it's awesome.
porschetub
post Jun 29 2017, 11:34 PM
Wow huge jets...why,those mains are massive, what vents are you running ,if that makes it go your vents are too big.
Bigger is not better,camshafts are the same (IMG:style_emoticons/default/sad.gif)
Tastyplacement   914 and 550, both T4, One Cold Starts, the Other Doesn't, Why?   Jun 24 2017, 08:11 PM
Rand   I've never had luck with carbs and no choke be...   Jun 24 2017, 08:13 PM
Tastyplacement   I've never had luck with carbs and no choke b...   Jun 24 2017, 10:40 PM
jvmarino   Maybe the spark plugs. My carb'd 914 2.0 was t...   Jun 24 2017, 08:21 PM
thelogo   I would think the more performance oriented Your ...   Jun 24 2017, 08:28 PM
arne   What cams in each?   Jun 24 2017, 08:47 PM
Tastyplacement   What cams in each? Actually, that's a good ...   Jun 24 2017, 10:38 PM
thelogo   I always thought cold start Meant like cold clima...   Jun 24 2017, 10:57 PM
Perry Kiehl   Performance cams usually mean less than stellar co...   Jun 25 2017, 11:38 AM
rhodyguy   Feather the throttle a bit on the big engine when ...   Jun 25 2017, 12:54 PM
r_towle   I may be wrong, but I think one of our vendors sel...   Jun 25 2017, 01:31 PM
Tastyplacement   How about going up one jet size (+5) on the idle j...   Jun 25 2017, 06:04 PM
Racer Chris   The 50s are too small for the 2.3L. 55 would be be...   Jun 26 2017, 09:31 AM
Tastyplacement   Thanks chris, I am going to try the 55s, which I h...   Jun 26 2017, 11:23 AM
porschetub   Wow huge jets...why,those mains are massive, what ...   Jun 29 2017, 11:34 PM
Racer Chris   Wow huge jets...why,those mains are massive, what...   Jun 30 2017, 08:38 AM
Rav914   Wow huge jets...why,those mains are massive, what...   Jun 30 2017, 08:29 AM
Edward Blume   :ttiwwp: Somebody had to do it. Lets see the 550 ...   Jun 30 2017, 09:47 AM
- Lo-Fi Version Time is now: 21st December 2024 - 11:07 PM
