> What modern EFI is everybody using, Modern EFI applications on Type-IV engine
TheWeatherMan
post Jul 5 2017, 12:45 PM
What modern EFI systems is everyone installing on their Type-IV engine?
Mark Henry
post Jul 6 2017, 07:35 AM
that's what I do!
I sold Dave his SDS system.
SDS is hands down the simplest system to get up and running, often the factory program will run straight out of the box good enough to get you going. I've locked in the rough fuel maps in as little as 30 minutes of driving time, no dyno.
But there's many computer guys who don't like the thought of a pendant programmed system. The pendant is definitely different, but once you know how the scroll function works with the rich/lean knob, changing values is very fast.
V5 now addresses most of that with the 8 channel data logging, I believe with this you can now program with both the pendant and the laptop.
Many also believe you have to have sequential, in aircooleds running 3000rpm, the speed for proper cooling, the fuel economy of sequential goes out the window.
SDS is not for everyone, but it is a pro built, proven (23 years), good bang for the buck.
SDS has three versions
EM5 (EM 3-and 4) Fuel only
EM5-MSD (EM 3-and 4-MSD) Fuel with crankfire for MSD dizzy based systems
EM5-F (EM 3-and 4-F) Fuel and crankfire. GM based coils, one for 2 cylinders
BTW owners of older V3 and V4 SDS systems can upgrade to V5 for $580. SDS takes your old system ECU, gut it and install a V5 board and drill the case to install the laptop connector.
I have several running systems that I sold and/or installed
A 930 600hp monster EM4-F twin plug
A 930 hot street (guessing 350-400hp) EM5-F twin plug (now MS see note below)
A few vw vans EM4 mostly fuel only, stock dizzy
2 914 EM4 one fuel only one -F crankfire.
my SDS EM4-F system, in my 2.6L type 4 powered bug
and several systems sold, owner installed.
I have one customer who went from a SDS to a MS just this year, in hindsight he said he should have just stuck with the SDS as he's seen no performance improvement. But he does say the MS has more bells and whistles and he wanted to run COP, play with his computer, etc..
If anyone wants a lightly used SDS EM5-F /6 twin plug system PM me and I'll see if it's still for sale. It has the latest V4 chip.
TheWeatherMan   What modern EFI is everybody using   Jul 5 2017, 12:45 PM
jd74914   I'm putting a MS3X (Megasquirt) on my 2.0L. No...   Jul 5 2017, 01:31 PM
jimkelly   seems very few have moved away from stock FI, and ...   Jul 5 2017, 02:52 PM
porschetub   There was a guy a few years back that used GM ECU ...   Jul 5 2017, 03:38 PM
914forme   There was a guy a few years back that used GM ECU...   Jul 5 2017, 09:06 PM
Mark Henry   I installed SDS way back in 2004, still running th...   Jul 5 2017, 03:54 PM
JamesM   PEFI alone adds no HP, but a proper tune on top of...   Jul 5 2017, 07:12 PM
914_teener   PEFI alone adds no HP, but a proper tune on top o...   Jul 5 2017, 07:42 PM
JamesM   So James.....just as an observer. What is the mi...   Jul 6 2017, 01:30 AM
Mark Henry   PEFI alone adds no HP, but a proper tune on top o...   Jul 5 2017, 08:19 PM
JamesM   Marketing Koolaid :D 3D tuning table? does t...   Jul 6 2017, 01:54 AM
Mueller   I would guess that there are 5 to 10+ 914s that ar...   Jul 5 2017, 04:14 PM
wndsrfr   I'm on SDS on the 2316 Raby kit engine that Dr...   Jul 5 2017, 07:47 PM
Dtjaden   Megasquirt MS3X full engine management (FI and ign...   Jul 5 2017, 08:39 PM
falcor75   Who's going to tune your car? If you know that...   Jul 5 2017, 10:30 PM
Mueller   [b]Who's going to tune your car? If you know ...   Jul 6 2017, 12:31 AM
falcor75   Must have: Crank position sensor Throttle position...   Jul 6 2017, 01:47 AM
JamesM   Must have: Crank position sensor Throttle positio...   Jul 6 2017, 02:11 AM
falcor75   Must have: Crank position sensor Throttle positi...   Jul 6 2017, 03:21 AM
jimkelly   microsquirt diagram   Jul 6 2017, 04:26 AM
ottox914   SDS. See my sig below for the install thread. It...   Jul 6 2017, 06:08 AM
Mark Henry   :agree: I sold Dave his SDS system. SDS is hand...   Jul 6 2017, 07:35 AM
Mark Henry   A member asked me if he should ditch his homebuilt...   Jul 6 2017, 11:52 AM
90quattrocoupe   Now before I start this post, I am not in anyway a...   Jul 6 2017, 12:40 PM
Mark Henry   That's one of the issues with many PEFI system...   Jul 7 2017, 09:51 AM
TheWeatherMan   Thanks, ill continue to research the SDS set up an...   Jul 7 2017, 10:37 AM
Mark Henry   Thanks, ill continue to research the SDS set up a...   Jul 7 2017, 11:38 AM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 09:42 PM
