Transmission shift rod removal, Isn't it just supposed to slide out? |
rad23racer |
Jul 6 2017, 09:28 AM
Newbie Group: Members Posts: 17 Joined: 28-May 17 From: Corona, CA Member No.: 21,137 Region Association: Southern California |
I'm trying to remove the shift rod from the linkage on the transmission so I can replace the bushing that is destroyed. I pulled the tapered screw out but this thing doesn't want to budge. Before I get creative, I thought I would check and see if there is a trick to getting the rod out.
Thanks... |
bdstone914 |
Jul 6 2017, 03:50 PM
bdstone914 Group: Members Posts: 4,663 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Twist the shift rod at the coupler to break the tension. put the shifter in 2nd or 4th. with one person at the shifter get under the car and open up an adjustable wrench to slide onto the exposed part of the front shift rod. have the person inside pul the shifter back to break loose the coupler from the front rod. might take a couple of smacks.
Lo-Fi Version | Time is now: 21st September 2024 - 06:52 PM |
