> What modern EFI is everybody using, Modern EFI applications on Type-IV engine
TheWeatherMan
post Jul 5 2017, 12:45 PM
What modern EFI systems is everyone installing on their Type-IV engine?
Mark Henry
post Jul 7 2017, 09:51 AM
that's what I do!
That's one of the issues with many PEFI systems, there's almost no way to dial them in without expensive dyno time. Most of this is because the programs are so complex you have to be a pro with a dyno to dial them in.
That's the main reason I try to steer a novice and/or lower budget guy towards SDS, no dyno needed and 98% of the time you can get a good fuel map without a pro.
Once you have that under your belt you can look at a more sophisticated system.
These's are not a bolt on solution and they're not cheap, including MS.
Also I can say with absolute certainty there's way more PEFI systems sitting on the guy's benches then successfully installed in cars.
TheWeatherMan   What modern EFI is everybody using   Jul 5 2017, 12:45 PM
jd74914   I'm putting a MS3X (Megasquirt) on my 2.0L. No...   Jul 5 2017, 01:31 PM
jimkelly   seems very few have moved away from stock FI, and ...   Jul 5 2017, 02:52 PM
porschetub   There was a guy a few years back that used GM ECU ...   Jul 5 2017, 03:38 PM
914forme   There was a guy a few years back that used GM ECU...   Jul 5 2017, 09:06 PM
Mark Henry   I installed SDS way back in 2004, still running th...   Jul 5 2017, 03:54 PM
JamesM   PEFI alone adds no HP, but a proper tune on top of...   Jul 5 2017, 07:12 PM
914_teener   PEFI alone adds no HP, but a proper tune on top o...   Jul 5 2017, 07:42 PM
JamesM   So James.....just as an observer. What is the mi...   Jul 6 2017, 01:30 AM
Mark Henry   PEFI alone adds no HP, but a proper tune on top o...   Jul 5 2017, 08:19 PM
JamesM   Marketing Koolaid :D 3D tuning table? does t...   Jul 6 2017, 01:54 AM
Mueller   I would guess that there are 5 to 10+ 914s that ar...   Jul 5 2017, 04:14 PM
wndsrfr   I'm on SDS on the 2316 Raby kit engine that Dr...   Jul 5 2017, 07:47 PM
Dtjaden   Megasquirt MS3X full engine management (FI and ign...   Jul 5 2017, 08:39 PM
falcor75   Who's going to tune your car? If you know that...   Jul 5 2017, 10:30 PM
Mueller   [b]Who's going to tune your car? If you know ...   Jul 6 2017, 12:31 AM
falcor75   Must have: Crank position sensor Throttle position...   Jul 6 2017, 01:47 AM
JamesM   Must have: Crank position sensor Throttle positio...   Jul 6 2017, 02:11 AM
falcor75   Must have: Crank position sensor Throttle positi...   Jul 6 2017, 03:21 AM
jimkelly   microsquirt diagram   Jul 6 2017, 04:26 AM
ottox914   SDS. See my sig below for the install thread. It...   Jul 6 2017, 06:08 AM
Mark Henry   :agree: I sold Dave his SDS system. SDS is hand...   Jul 6 2017, 07:35 AM
Mark Henry   A member asked me if he should ditch his homebuilt...   Jul 6 2017, 11:52 AM
90quattrocoupe   Now before I start this post, I am not in anyway a...   Jul 6 2017, 12:40 PM
Mark Henry   That's one of the issues with many PEFI system...   Jul 7 2017, 09:51 AM
TheWeatherMan   Thanks, ill continue to research the SDS set up an...   Jul 7 2017, 10:37 AM
Mark Henry   Thanks, ill continue to research the SDS set up a...   Jul 7 2017, 11:38 AM
- Lo-Fi Version Time is now: 26th December 2024 - 09:03 PM
