bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Hoping to get some BTDT wisdom. I'm simply trying to remove the passenger side door handle and hit a major snag. The little M6 stud that attaches to the tab on the outer part of the handle is just spinning free so I can't get the self-locking nut off.
(IMG:http://www.914world.com/bbs2/uploads_offsite/cdn4.pelicanparts.com-20845-1499725820.1.JPG) It isn't broken, it is still attached to the tab on the door handle, but loose inside. I've tried soaking the nut with PB Blaster, heating it with a propane torch, and trying to wedge a flat blade screw driver against the stud in an attempt to create more friction resisting the stud turning than needed to break the nut loose. There isn't a lot of room in there to work and I know from sad experience how easy it is to break the pot metal on these things. The only options I see now involve a drill and destroying the stud, or drilling in from the outer (tab) side to try to pin the stud enough to get the nut off. Either way, I need to make sure there is a path forward for a good repair. Even better would be the third option that you are going to tell me about (IMG:style_emoticons/default/smile.gif) |
arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 776 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
If the stud is spinning, it has a problem and there's no reason to worry about damaging it. It will need to be replaced anyway, perhaps with an oversized stud. I believe that someone here on World can repair these handles.
Specracer |
Member ![]() ![]() Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None ![]() |
im dealing with the same issue. I'll be cutting the nut off. Once I get it apart, hoping to fix the stud with a bonding adhesive.
One solution I read about here, is a flat head screw (head exposed on the outside). |
bbrock |
im dealing with the same issue. I'll be cutting the nut off. Once I get it apart, hoping to fix the stud with a bonding adhesive. One solution I read about here, is a flat head screw (head exposed on the outside). That could work (IMG:style_emoticons/default/beerchug.gif) I would think good old JB Weld would hold it tight. Does anyone know how these things are attached at the factory? Looking at my good one, It kind of looks like the stud has a button head that was press fit into the tab prior to plating. But I can't really tell for sure. |
Lo-Fi Version | Time is now: 19th April 2025 - 02:52 AM |
