bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Hoping to get some BTDT wisdom. I'm simply trying to remove the passenger side door handle and hit a major snag. The little M6 stud that attaches to the tab on the outer part of the handle is just spinning free so I can't get the self-locking nut off.
(IMG:http://www.914world.com/bbs2/uploads_offsite/cdn4.pelicanparts.com-20845-1499725820.1.JPG) It isn't broken, it is still attached to the tab on the door handle, but loose inside. I've tried soaking the nut with PB Blaster, heating it with a propane torch, and trying to wedge a flat blade screw driver against the stud in an attempt to create more friction resisting the stud turning than needed to break the nut loose. There isn't a lot of room in there to work and I know from sad experience how easy it is to break the pot metal on these things. The only options I see now involve a drill and destroying the stud, or drilling in from the outer (tab) side to try to pin the stud enough to get the nut off. Either way, I need to make sure there is a path forward for a good repair. Even better would be the third option that you are going to tell me about (IMG:style_emoticons/default/smile.gif) |
arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 776 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
If the stud is spinning, it has a problem and there's no reason to worry about damaging it. It will need to be replaced anyway, perhaps with an oversized stud. I believe that someone here on World can repair these handles.
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 126,087 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I believe that someone here on World can repair these handles. That would be me. (IMG:style_emoticons/default/biggrin.gif) Cut off the stud/nut. Remove the handle. Drill the out stud. Replace the stud with a bolt or counter sink a screw. If (or when) you break the mounting tab off when doing this, send it to me and I'll replace the tab. |
bbrock |
I believe that someone here on World can repair these handles. That would be me. (IMG:style_emoticons/default/biggrin.gif) Cut off the stud/nut. Remove the handle. Drill the out stud. Replace the stud with a bolt or counter sink a screw. If (or when) you break the mounting tab off when doing this, send it to me and I'll replace the tab. That's what I'm looking for! A backup plan to my inevitable screw up. Thanks. |
Lo-Fi Version | Time is now: 19th April 2025 - 02:52 AM |
