> Rebuilding Throttle Bodies, New service. No more sticky throttle!
Bartlett 914
post Jul 17 2017, 06:22 PM
Recently I got tired of my sticky uneven throttle body. I was stuck in construction traffic and inching forward became almost impossible. I decided to repair mine. The throttle body shaft has no bearing. It is steel against aluminum. In time the round hole becomes an oval one. This makes the throttle plate operate erratically. It even sticks when in the closed position.
I made a setup in my machine shop to repair these. I accurately locate the shaft hole and boar it to fit an oilite bushing. I have done a dozen of these so far. In my car, the difference was incredible. I expected the operation off idle to be improved which it did but I also found the operation was smoother through the operating range.
I decided I could offer this as a service. In this, I will clean the body and install the new bushings. This operation requires special machining in order to keep things aligned properly. At this point, I am not plating anything. I am only cleaning the steel components. I may offer plated parts later but not at this time. I will need a core in exchange for one I send out or I can repair yours but there will be a delay in doing this. There are some that have 2 ports and some with only one. Some have a built in return spring and the other does not. You can see the differences in the ones pictured.
If you are interested in this service, My starting price is $125.00 plus shipping
solex
post Jul 19 2017, 08:09 AM
I'm interested as well, do you offer core service so my car is not down during the process?
Bartlett 914
post Jul 19 2017, 08:40 AM
QUOTE(solex @ Jul 19 2017, 09:09 AM) *
I can do that!
solex
post Jul 19 2017, 09:41 AM
QUOTE(Bartlett 914 @ Jul 19 2017, 10:40 AM) *
I can do that!
Let me know what needs to be done. I have a 75' throttle body with a built in return spring.
I also seem to remember someone offering to open up the throat with a larger throttle plate, does this offer any performance enhancement?
Bartlett 914
post Jul 19 2017, 11:44 AM
QUOTE(solex @ Jul 19 2017, 10:41 AM) *
I can do that!
I am planning on making this available also
solex
post Jul 19 2017, 01:46 PM
QUOTE(Bartlett 914 @ Jul 19 2017, 01:44 PM) *
I can do that!
Mark or Anyone does modification this make an appreciable difference with a stock euro piston 2.0L with SS heat exchanges and Bursch exhaust.
thanks
Bartlett 914   Rebuilding Throttle Bodies   Jul 17 2017, 06:22 PM
914Sixer   Sounds like a great deal! :D   Jul 17 2017, 06:26 PM
Garold Shaffer   Recently I got tired of my sticky uneven throttle...   Jul 17 2017, 09:09 PM
euro911   Nice. Have you thought about doing this with Weber...   Jul 17 2017, 09:34 PM
Bartlett 914   Nice. Have you thought about doing this with Webe...   Jul 17 2017, 10:21 PM
Dave_Darling   The late Mike Cooley also provided this service. ...   Jul 17 2017, 10:03 PM
burton73   Harry Bieker of Bicker engineering did Webbers but...   Jul 17 2017, 10:16 PM
McMark   Definitely interested. But I need plated parts, s...   Jul 18 2017, 09:44 AM
Bartlett 914   Definitely interested. But I need plated parts, ...   Jul 18 2017, 10:30 AM
Shadowfax   Very interested in this service. I can send it to ...   Jul 18 2017, 12:09 PM
solex   I'm interested as well, do you offer core serv...   Jul 19 2017, 08:09 AM
Bartlett 914   I'm interested as well, do you offer core ser...   Jul 19 2017, 08:40 AM
solex   I'm interested as well, do you offer core se...   Jul 19 2017, 09:41 AM
Bartlett 914   [quote name='Bartlett 914' post='2507884' date='J...   Jul 19 2017, 11:44 AM
solex   [quote name='Bartlett 914' post='2507884' date='...   Jul 19 2017, 01:46 PM
Bartlett 914   [quote name='Bartlett 914' post='2507941' date='J...   Jul 19 2017, 02:15 PM
Whip618   [quote name='Bartlett 914' post='2507941' date='...   Jul 19 2017, 07:25 PM
McMark   Got a spare TB stripped down. Wire brushed all th...   Jul 19 2017, 08:28 AM
Bartlett 914   Got a spare TB stripped down. Wire brushed all t...   Jul 19 2017, 08:44 AM
euro911   Hi Mark That look really nice. I realized more pe...   Jul 19 2017, 07:06 PM
Bartlett 914   [quote name='Bartlett 914' post='2507885' date='J...   Jul 19 2017, 07:32 PM
euro911   Need to be vigilant with thorough cleaning when be...   Jul 20 2017, 02:05 AM
Bartlett 914   [quote name='Bartlett 914' post='2508099' date='J...   Jul 20 2017, 07:02 AM
Mark Henry   Pine-sol will do a real good job cleaning the bare...   Jul 19 2017, 07:56 PM
Bartlett 914   Pine-sol will do a real good job cleaning the bar...   Jul 20 2017, 07:03 AM
Dave_Darling   Walnut-shell blasting is popular for cleaning port...   Jul 20 2017, 11:35 AM
solex   Mark, I'm in and sent you a message and pictur...   Jul 25 2017, 06:52 AM
Shadowfax   Bump for a great service. Installed my refurbished...   Jul 28 2017, 06:31 AM
Bartlett 914   Bump for a great service. Installed my refurbishe...   Jul 28 2017, 05:24 PM
solex   I shadow, Shadowfax's sentiments.. I received...   Jul 28 2017, 06:59 AM
solex   Installed the TB today set the TPS, Dwell and Idle...   Jul 29 2017, 12:03 PM
euro911   Installed the TB today set the TPS, Dwell and Idle...   Jul 29 2017, 02:21 PM
Bartlett 914   I am glad you like it!   Jul 29 2017, 12:32 PM
larryM   how about adding an overbore option like Ed Mazula...   Jul 29 2017, 10:09 PM
McMark   Got mine back a little while ago and finally took ...   Sep 12 2017, 10:43 AM
sdthomas   Mark are you still offering this service? Sent yo...   Sep 25 2017, 12:28 PM
mdalcorn   Recently I got tired of my sticky uneven throttle...   Sep 16 2022, 03:50 PM
StarBear   Ditto?   Sep 16 2022, 04:03 PM
TJB/914   :) Mark rebuilt my throttle body this summer. :fi...   Sep 16 2022, 04:31 PM
TJB/914   :) Mark rebuilt my throttle body this summer. :f...   Sep 16 2022, 04:38 PM
Van B   Well take a finished photo Tom! We’ll wait :...   Sep 16 2022, 08:02 PM
914werke   :shades2:   Apr 29 2025, 01:47 PM
- Lo-Fi Version Time is now: 30th April 2025 - 06:28 AM
