bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Hoping to get some BTDT wisdom. I'm simply trying to remove the passenger side door handle and hit a major snag. The little M6 stud that attaches to the tab on the outer part of the handle is just spinning free so I can't get the self-locking nut off.
(IMG:http://www.914world.com/bbs2/uploads_offsite/cdn4.pelicanparts.com-20845-1499725820.1.JPG) It isn't broken, it is still attached to the tab on the door handle, but loose inside. I've tried soaking the nut with PB Blaster, heating it with a propane torch, and trying to wedge a flat blade screw driver against the stud in an attempt to create more friction resisting the stud turning than needed to break the nut loose. There isn't a lot of room in there to work and I know from sad experience how easy it is to break the pot metal on these things. The only options I see now involve a drill and destroying the stud, or drilling in from the outer (tab) side to try to pin the stud enough to get the nut off. Either way, I need to make sure there is a path forward for a good repair. Even better would be the third option that you are going to tell me about (IMG:style_emoticons/default/smile.gif) |
colingreene |
Senior Member ![]() ![]() ![]() Group: Members Posts: 734 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California ![]() |
I have a ton of spare door handles if you happen to go that route after you cut it off.
bbrock |
I have a ton of spare door handles if you happen to go that route after you cut it off. Out of curiosity, what would you want for a right side? Last night I got a change to try the slot method. It was easy to cut a slot with a dremel and cutoff wheel just right to slip a flat blade screwdriver into. Should have worked perfectly - but didn't. (IMG:style_emoticons/default/headbang.gif) I couldn't hold the screwdriver tight enough to get the nut to budge. I ended up slicing the stud lengthwise all the way down to cut the nut in half. Mine was rusted just enough to make the slot trick not work. Still, I think that is the way to go. Had it worked, the stud would have still been perfectly serviceable once something was done to keep it from spinning. But the handle is off and now I need to drill out the old stud and replace it somehow. Anyone know the correct replacement for that peened pin hinge shaft? If I can get the flapper side of the handle off, I think I could replace the stud with a nearly invisible repair. |
Lo-Fi Version | Time is now: 19th April 2025 - 02:52 AM |
