Aualexa1 |
Newbie ![]() Group: Members Posts: 45 Joined: 17-June 17 From: South Jersey Member No.: 21,189 Region Association: MidAtlantic Region ![]() |
I ordered new Bilstein strut inserts (part number 34-001127-M512) to replace the old Koni's (part number 82R-1730) that I removed from my '73 914. Both inserts should fit a Boge strut, but the new Bilsteins are too tall (about 3 mm longer than the Koni's) and don't fit the strut housing. Any idea what's wrong? Did I order the wrong part?
Attached thumbnail(s) ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
If you are talking about the collar not fitting flat against the tube, that is just the way the fit.
Aualexa1 |
If you are talking about the collar not fitting flat against the tube, that is just the way the fit. When I put the insert into the strut housing, I can't get the threads to engage in order to screw the insert into the housing. The insert is just a little too high. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:03 PM |
