laser cutting, emblems |
peteyd |
Jul 24 2017, 10:07 AM
Senior Member Group: Members Posts: 708 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
We have a laser here that we cut all our sheet metal with. These pieces are cut from .05" or 18 gauge. I can cut thicker up to 1" but at that point the slag on the edges isn't too pretty.
I was thinking I can cut custom 914 emblems if that is of interest to anyone. I have the pins mapped out if that makes any difference. 18 gauge thick $12 thicker stuff will have to be priced out accordingly. Pete |
peteyd |
Jul 28 2017, 02:07 PM
We went with Mitsubishi because the resonators last 20+ years. Trumpf lasers have a reputation for needing them to be replaced after 5-10 years at a cost of 50k. I dont know about the Mazak though. We shopped them when buying our 5 axis, but didnt end up buying one because the Mits was a better machine for 5 axis.
even though ours is a C02, we use nitrogen for the majority of our cuts. You need C02 when cutting thicker material. Nitrogen is very cheap as well. Here is my rendition of the 914/6 badge. My original is at home right now so I cant be certain all the dimension for the #6 is correct, but the 914 is correct according to just a normal badge. |
mb911 |
Jul 28 2017, 02:26 PM
914 Guru Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
We went with Mitsubishi because the resonators last 20+ years. Trumpf lasers have a reputation for needing them to be replaced after 5-10 years at a cost of 50k. I dont know about the Mazak though. We shopped them when buying our 5 axis, but didnt end up buying one because the Mits was a better machine for 5 axis. even though ours is a C02, we use nitrogen for the majority of our cuts. You need C02 when cutting thicker material. Nitrogen is very cheap as well. Here is my rendition of the 914/6 badge. My original is at home right now so I cant be certain all the dimension for the #6 is correct, but the 914 is correct according to just a normal badge. Looks great.. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:17 PM |
