jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I'm installing the new 914Rubber HID headlights; new to know whether the plastic cover/shell over the front of the HID is supposed to stay or be removed
1st pic shows that cover partially off 2nd pic is the cover on and the end-thingy screwed in... Attached image(s) ![]() ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The cover stays on. It actually helps make them waterproof. There is also a second set included.
jim_hoyland |
The cover stays on. It actually helps make them waterproof. There is also a second set included. Thanks ! And I found the second set, kinda hard to see if I didn't know they were packed in the foam..... Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 08:32 AM |
