> Cibie Hesdlights?
Jameel
post Aug 9 2017, 12:20 PM
My headlights are pretty dim. I try not to drive at night. So I'm thinking of ordering a set of H4s. But I noticed that current lights look like Cibie's with replacable bulbs. I'm going to pop them open today to get a close look. Does anyone recognize what I've got here?Attached Image
7TPorsh
post Aug 9 2017, 12:27 PM
7T Porsh
Those are good headlights.Are they sealed beam? Issue may be not enough electrical current or a bad bulb. Check the voltage. Get new bulbs...
Jameel   Cibie Hesdlights?   Aug 9 2017, 12:20 PM
7TPorsh   Those are good headlights.Are they sealed beam? I...   Aug 9 2017, 12:27 PM
arne   CibiĆ© BOBI. A semi-sealed H4 headlight, made spec...   Aug 9 2017, 12:43 PM
ConeDodger   Change the bulbs and clean your grounds. Or, buy s...   Aug 9 2017, 12:44 PM
11tenths   Plenty info here: http://www.danielsternlighting....   Aug 9 2017, 12:48 PM
rgalla9146   A poor ground is far more likely than insufficient...   Aug 9 2017, 01:41 PM
arne   A poor ground is far more likely than insufficien...   Aug 9 2017, 02:38 PM
rgalla9146   A poor ground is far more likely than insufficie...   Aug 10 2017, 05:27 AM
anderssj   correct about current draw....add relays :ag...   Aug 10 2017, 06:35 AM
Jameel   These headlights ended up being in great shape. To...   Aug 9 2017, 07:14 PM
lonewolfe   These headlights ended up being in great shape. T...   Aug 10 2017, 12:27 AM
Mikey914   They should work very well. Do a before and after ...   Aug 10 2017, 02:51 AM
Jameel   Steve, GREAT info. Looks like I should track down ...   Aug 10 2017, 07:25 PM
Jameel   So....headlights are dreadfully dim. And I couldnt...   Aug 10 2017, 08:24 PM
Jameel   Put new battery connectors on, a new negative lead...   Aug 14 2017, 06:51 AM
Jameel   I ended up buying a new voltage regulator. Now I...   Aug 20 2017, 08:22 PM
arne   ...or perhaps too high of expectations. Thing is,...   Aug 21 2017, 08:37 AM
Jameel   ...or perhaps too high of expectations. Thing is...   Aug 23 2017, 09:58 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:03 PM
