> Cibie Hesdlights?
Jameel
post Aug 9 2017, 12:20 PM
My headlights are pretty dim. I try not to drive at night. So I'm thinking of ordering a set of H4s. But I noticed that current lights look like Cibie's with replacable bulbs. I'm going to pop them open today to get a close look. Does anyone recognize what I've got here?Attached Image
arne
post Aug 9 2017, 12:43 PM
Serial Rescuer of old vehicles...
CibiƩ BOBI. A semi-sealed H4 headlight, made specially for the US. DOT legal as it had a glass balloon inside to seal the lens and reflector assembly while still allowing use of normal, replaceable H4 bulbs. Actually pretty good lights. I ran a pair in a Chevy pickup back in the 80s.
So I doubt your dimness is bad lights. Perhaps bad ground, too low voltage (too much voltage drop in the wiring), or perhaps too high of expectations.
Thing is, even decent H4s are not going to be equal to modern headlights. A relay set may help, by getting more volts to the lights.
Jameel   Cibie Hesdlights?   Aug 9 2017, 12:20 PM
7TPorsh   Those are good headlights.Are they sealed beam? I...   Aug 9 2017, 12:27 PM
arne   CibiĆ© BOBI. A semi-sealed H4 headlight, made spec...   Aug 9 2017, 12:43 PM
ConeDodger   Change the bulbs and clean your grounds. Or, buy s...   Aug 9 2017, 12:44 PM
11tenths   Plenty info here: http://www.danielsternlighting....   Aug 9 2017, 12:48 PM
rgalla9146   A poor ground is far more likely than insufficient...   Aug 9 2017, 01:41 PM
arne   A poor ground is far more likely than insufficien...   Aug 9 2017, 02:38 PM
rgalla9146   A poor ground is far more likely than insufficie...   Aug 10 2017, 05:27 AM
anderssj   correct about current draw....add relays :ag...   Aug 10 2017, 06:35 AM
Jameel   These headlights ended up being in great shape. To...   Aug 9 2017, 07:14 PM
lonewolfe   These headlights ended up being in great shape. T...   Aug 10 2017, 12:27 AM
Mikey914   They should work very well. Do a before and after ...   Aug 10 2017, 02:51 AM
Jameel   Steve, GREAT info. Looks like I should track down ...   Aug 10 2017, 07:25 PM
Jameel   So....headlights are dreadfully dim. And I couldnt...   Aug 10 2017, 08:24 PM
Jameel   Put new battery connectors on, a new negative lead...   Aug 14 2017, 06:51 AM
Jameel   I ended up buying a new voltage regulator. Now I...   Aug 20 2017, 08:22 PM
arne   ...or perhaps too high of expectations. Thing is,...   Aug 21 2017, 08:37 AM
Jameel   ...or perhaps too high of expectations. Thing is...   Aug 23 2017, 09:58 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:01 PM
