New GB Tail light lenses US and Euro $195 a set with seals !, Who's in? |
Mikey914 |
Aug 10 2017, 12:14 AM
The rubber man Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
US and Euro lenses $195 a set. Same price
These are multi port injected lenses. What does that mean? THEY ARE NOT GLUED TOGETHER !! Yes, they will not crack apart or have ridges like others we have seen. The price includes the right and left lenses with the lens to housing seals. The self adhesive housing to body seals will be 1/2 off if you wan them. The only drawback with this method of injection is that on the edges the hot resin melts the previously injected resin, so the edges are not a prefect line. You can see this on the edge of the clear easiest. The edges do stick out a little further we are reworking these right now to minimize this. Pictures to follow. Here's the ones Matt just fitted to his car. Attached thumbnail(s) |
Mikey914 |
Aug 11 2017, 11:47 PM
It's actually an imperfection in design. Will require retooling. A section is slightly too large and makes it sit a little farther out. Honestly I think the AA ones do this too.
I'm just telling you. You can make the decision. If you are a CW and have OCD, I'd say wait another year when it's revisited. I can say they will be more expensive. You have a good daily driver to a driving restoration you'll benefit from lenses that will not break apart and are actually smooth. It's not lithe casual observer could tell. And with the extra seal we are including it will help Keep water out. Mark |
Lo-Fi Version | Time is now: 18th June 2024 - 05:41 AM |
