Clean up wiring ailse 6. What are these relays?, Where do I find a full car wiring diagram? |
drem914 |
Aug 13 2017, 05:48 PM
Senior Member Group: Members Posts: 1,051 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
I was going to go in and replace my headlights and front turn signals lights with the 914rubber LED set up and Spokes turn signal boards, but ran into some wiring and relays that don't make any sense.
Before I got started I checked the existing operation and found everything works except for the driver's side high beam does not come on. Next I went and started pulling the headlamp covers off, but before I could I noticed these relays connect to the headlamp harness. Anyone know what this might be? Secondly, you can see by the harness pictures where they had spliced into the wires. passenger side light driver's side light Is this part of an alarm connection to the turn signal lighting? (I had an alarm system installed way back in '85 when I used to park my car outside in an apartment complex.) If so, how do I get the wiring back to normal? |
drem914 |
Aug 13 2017, 06:54 PM
Where would I find a wiring diagram for the wiring harnesses? Is there a download or do I have to search out an old hard copy somewhere?
worn |
Aug 13 2017, 07:53 PM
can't remember Group: Members Posts: 3,378 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I am going to say you have an intermittent wiper function. The stock intermittent relay works as a single relay, changing a switch from ground to no contact into a six second delay between wipes.
The more readily available vw relay requires a stalk switch signal that goes from ground to 12 v. To get that, you need an intermediary relay. I am going by the position of the relays, not the wiring. How close did I get? |
Lo-Fi Version | Time is now: 6th January 2025 - 08:27 PM |
