> Cibie Hesdlights?
Jameel
post Aug 9 2017, 12:20 PM
My headlights are pretty dim. I try not to drive at night. So I'm thinking of ordering a set of H4s. But I noticed that current lights look like Cibie's with replacable bulbs. I'm going to pop them open today to get a close look. Does anyone recognize what I've got here?Attached Image
Jameel
post Aug 20 2017, 08:22 PM
I ended up buying a new voltage regulator. Now I'm getting 14V at the batt with the engine running. So that's good. Cleaned the grounds up front and now I'm getting 12.5v at the headlight plug. Lights are way better than before, but not exactly confidence inspiring. 55w h4's, brand new bulbs. It's totally drivable, but brighter would be nice.
Jameel   Cibie Hesdlights?   Aug 9 2017, 12:20 PM
7TPorsh   Those are good headlights.Are they sealed beam? I...   Aug 9 2017, 12:27 PM
arne   CibiĆ© BOBI. A semi-sealed H4 headlight, made spec...   Aug 9 2017, 12:43 PM
ConeDodger   Change the bulbs and clean your grounds. Or, buy s...   Aug 9 2017, 12:44 PM
11tenths   Plenty info here: http://www.danielsternlighting....   Aug 9 2017, 12:48 PM
rgalla9146   A poor ground is far more likely than insufficient...   Aug 9 2017, 01:41 PM
arne   A poor ground is far more likely than insufficien...   Aug 9 2017, 02:38 PM
rgalla9146   A poor ground is far more likely than insufficie...   Aug 10 2017, 05:27 AM
anderssj   correct about current draw....add relays :ag...   Aug 10 2017, 06:35 AM
Jameel   These headlights ended up being in great shape. To...   Aug 9 2017, 07:14 PM
lonewolfe   These headlights ended up being in great shape. T...   Aug 10 2017, 12:27 AM
Mikey914   They should work very well. Do a before and after ...   Aug 10 2017, 02:51 AM
Jameel   Steve, GREAT info. Looks like I should track down ...   Aug 10 2017, 07:25 PM
Jameel   So....headlights are dreadfully dim. And I couldnt...   Aug 10 2017, 08:24 PM
Jameel   Put new battery connectors on, a new negative lead...   Aug 14 2017, 06:51 AM
Jameel   I ended up buying a new voltage regulator. Now I...   Aug 20 2017, 08:22 PM
arne   ...or perhaps too high of expectations. Thing is,...   Aug 21 2017, 08:37 AM
Jameel   ...or perhaps too high of expectations. Thing is...   Aug 23 2017, 09:58 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:24 PM
