LEDs and housings in stock see post 48----GB ENDS 8/1/17, Got more back in for those that need them |
Mikey914 |
Nov 2 2016, 12:35 AM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've been able to source some very good LEDs for our car. It took some trial and error, but have been able to locate and check fit to assure these will work on our cars
Option 1- I have H4 housings just want LEDs I know will fit without any issues - Not DOT approved 2600 lumens- $32 per bulb Option 2- I have H4 housings want the BEST LED I know will fit that DOT approved Watertight 3000 lumens $48 bulb Option 3-Plug and play Jeep series LED complete housed unit DOT approved 3000 lumens $98 per unit. For those that want New H4 no sealed beam housings we are looking at buying in bulk and providing at cost. So don't worry if you don't have an H4 housing. They are not that expensive, and we will try to get the best price possible for them. We may be able to do better on these is we can get some volume, but wanted to test the waters. Pictures to follow Attached thumbnail(s) |
porschetub |
Aug 20 2017, 06:33 PM
Advanced Member Group: Members Posts: 4,756 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I've been able to source some very good LEDs for our car. It took some trial and error, but have been able to locate and check fit to assure these will work on our cars Option 1- I have H4 housings just want LEDs I know will fit without any issues - Not DOT approved 2600 lumens- $32 per bulb Option 2- I have H4 housings want the BEST LED I know will fit that DOT approved Watertight 3000 lumens $48 bulb Option 3-Plug and play Jeep series LED complete housed unit DOT approved 3000 lumens $98 per unit. For those that want New H4 no sealed beam housings we are looking at buying in bulk and providing at cost. So don't worry if you don't have an H4 housing. They are not that expensive, and we will try to get the best price possible for them. We may be able to do better on these is we can get some volume, but wanted to test the waters. Pictures to follow what is the function of the square box I did notice similar units don't use them,is it a ballast or transformer ??? I really don't , (IMG:style_emoticons/default/beer.gif) |
Spoke |
Aug 20 2017, 09:08 PM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
what is the function of the square box I did notice similar units don't use them,is it a ballast or transformer ??? I really don't , (IMG:style_emoticons/default/beer.gif) You're close with the transformer. Most likely it's a dc-dc converter to convert the constant 12-14Vdc input power to a constant output current to the LEDs. LEDs are controlled by current, not voltage. A dc-dc converter is usually very efficient and doesn't get too hot. |
Lo-Fi Version | Time is now: 27th December 2024 - 11:04 PM |
