> Cibie Hesdlights?
Jameel
post Aug 9 2017, 12:20 PM
My headlights are pretty dim. I try not to drive at night. So I'm thinking of ordering a set of H4s. But I noticed that current lights look like Cibie's with replacable bulbs. I'm going to pop them open today to get a close look. Does anyone recognize what I've got here?Attached Image
Jameel
post Aug 23 2017, 09:58 PM
QUOTE(arne @ Aug 21 2017, 06:37 AM) *
QUOTE(arne @ Aug 9 2017, 11:43 AM) *
...or perhaps too high of expectations.
Thing is, even decent H4s are not going to be equal to modern headlights.
Now that you have power and ground worked out, you could try higher wattage bulbs, preferably with relays to prevent overloading the headlight switch and dimmer relay. But in my experience, once you have full voltage going to the lights, the difference between 55/60 watts and 80 or even 100 watts is actually pretty hard to tell, and the hotter bulbs have a much shorter life span.
As I said above, it's going to be really hard to make 7" lights in a 914 perform even close to modern expectations. Today's HID and LED lights are much better lights. You may see some improvement by putting LED bulbs in those housings, but since the housings were designed for halogen bulbs, you still won't get light output that is on par with modern cars. The light housings are not optimized for newer light sources.
I'm leaning towards LED's from Mark at the moment. This time of year its really easy to head out for the evening and end up driving home in the dark. Buddy hit a deer in his '71 911S a couple months ago, so this topic is at the forefront for me.
Jameel   Cibie Hesdlights?   Aug 9 2017, 12:20 PM
7TPorsh   Those are good headlights.Are they sealed beam? I...   Aug 9 2017, 12:27 PM
arne   CibiĆ© BOBI. A semi-sealed H4 headlight, made spec...   Aug 9 2017, 12:43 PM
ConeDodger   Change the bulbs and clean your grounds. Or, buy s...   Aug 9 2017, 12:44 PM
11tenths   Plenty info here: http://www.danielsternlighting....   Aug 9 2017, 12:48 PM
rgalla9146   A poor ground is far more likely than insufficient...   Aug 9 2017, 01:41 PM
arne   A poor ground is far more likely than insufficien...   Aug 9 2017, 02:38 PM
rgalla9146   A poor ground is far more likely than insufficie...   Aug 10 2017, 05:27 AM
anderssj   correct about current draw....add relays :ag...   Aug 10 2017, 06:35 AM
Jameel   These headlights ended up being in great shape. To...   Aug 9 2017, 07:14 PM
lonewolfe   These headlights ended up being in great shape. T...   Aug 10 2017, 12:27 AM
Mikey914   They should work very well. Do a before and after ...   Aug 10 2017, 02:51 AM
Jameel   Steve, GREAT info. Looks like I should track down ...   Aug 10 2017, 07:25 PM
Jameel   So....headlights are dreadfully dim. And I couldnt...   Aug 10 2017, 08:24 PM
Jameel   Put new battery connectors on, a new negative lead...   Aug 14 2017, 06:51 AM
Jameel   I ended up buying a new voltage regulator. Now I...   Aug 20 2017, 08:22 PM
arne   ...or perhaps too high of expectations. Thing is,...   Aug 21 2017, 08:37 AM
Jameel   ...or perhaps too high of expectations. Thing is...   Aug 23 2017, 09:58 PM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 06:43 PM
