Three "planes" in the shifter console on the trans, But is seems I can only find two.....help? |
db9146 |
Aug 26 2017, 05:41 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Okay, so today, I was working on getting the shifter and new linkage adjusted.
Since I wasn't converting to any other trans (cable-shift, etc), I decided to change out the tail-shift for a side-shift. To do this, I went with the Tangerine Racing complete shift linkage kit, the firewall bushing, and the precision adjuster and threw in the JWest Renn-shifter for the heck of it (and to get the short-shift feature). When I shift the trans console by hand, I can find the reverse - 1st plane here: and I can find what I think is the 2nd-3rd plane about 7mm down: And then at about 13-14mm (the measurement I get with the level pulled all the way out), I would think would be the 4th - 5th plane but I can't shift the trans into 4th or 5th as I would expect. I have tried to split the difference between the R-1 plane and the 2-3 plane thinking that the 2-3 plane might actually be the 4-5 plane but that didn't work. This is an unfamiliar trans that I pulled out of a parts car I purchased (haven't had the time to go through it and it was recommended that I put it in and run it anyway to see what it needed). Am I missing something? I don't remember pulling the console out of it (as if I had not gotten it back in right and somehow had a shift rod out of alignment). Any thoughts? I've been trying to make sure that I have the trans in neutral (in between 2-3) and then adjust the shift rod in the console to the left to get it all lined up but when I do I can't find 4-5 with the shifter so I thought I'd try to find it at the console first.....but no luck yet. I have read a number of the "how to adjust your shifter" threads. |
ChrisFoley |
Aug 27 2017, 10:37 PM
I am Tangerine Racing Group: Members Posts: 7,968 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
while the console was out you should have tried moving the 4-5 fork into both gear positions with a big ass screwdriver.
Lo-Fi Version | Time is now: 27th December 2024 - 11:48 AM |
