HOW to Replace intake Gaskets?, 2.0 D-Jet |
rfinegan |
Aug 28 2017, 06:10 AM
Senior Member Group: Members Posts: 1,038 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I order up some replacement intake gaskets for my retro fit of the D-Jet back onto my 2.0l from Webers. My question is about the plastic intake gaskets and the addition of sealant or paper gaskets to go with them. The replacements look to be plastic phenolic with out paper on each side like i have seen and used in the past. Do I need to add the paper gaskets with the new phenolics? I have used aviation sealant in the past and was successfully sealing the IDF manifolds. Any advise would be appreciated
Best Regards -Robert |
Spoke |
Aug 28 2017, 11:26 AM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I made my own paper gaskets from gasket material from my FLAPS.
Cut the holes for the bolts and sandwiched the paper between the 2 spacers and bolted together. Used a razor knife to cut to shape. Took about 15 minutes to make 4 gaskets. Attached image(s) |
Kansas 914 |
Aug 28 2017, 12:31 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Kansas 914 |
Aug 28 2017, 01:21 PM
I remember McMark saying the few sets he ordered from a vendor came without the paper on the gaskets.
Many years ago they used to come with the paper - things might be changing depending on the vendor. |
era vulgaris |
Aug 28 2017, 02:28 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
I remember McMark saying the few sets he ordered from a vendor came without the paper on the gaskets. Many years ago they used to come with the paper - things might be changing depending on the vendor. (IMG:style_emoticons/default/agree.gif) When I replaced the gaskets on my old 1.7 back in 2013, they came with paper. When I replaced them on my 2270 a year ago, they did not. Both times I bought them from Pelican. I attempted to use the non-paper-having ones anyway, and the result was a vacuum leak. You will have to add a paper gasket to each side of the phenolic. Depending on how long your intake studs are, you might be able to use the cardboard/paper ones that CB Performance sells, which I was able to do just barely. Or you can cut out your own paper ones, as someone else mentioned. |
Lo-Fi Version | Time is now: 21st December 2024 - 09:44 PM |
