Steering column bearing - how to?, Now need advice on replacing top column bearing |
arne |
Aug 24 2017, 06:31 PM
Serial Rescuer of old vehicles... Group: Members Posts: 770 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
So....
The steering column on my '73 has play at the wheel. When this happened on my 911 I bought a plastic sleeve from Mitch that fit in and took care of the problem. When I search for confirmation of what I need for the 914, I find conflicting info. Some say a similar sleeve, others say that only works on /6 cars, I need real bearings. Or maybe I need to remove the column entirely and rebuild it? So can someone please confirm what I need to fix this in a 1973 914? |
euro911 |
Aug 31 2017, 02:45 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
So the bearing is shot?
I couldn't find anything in the Pelican tech articles (except for the bush/sleeve replacement). There's two bearings in the column, upper and lower. Pelican only lists the lower. I don't know if they're the same as the upper ... maybe a call to them will yield results (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 01:13 PM |
