> Hard starting when cold, Is this what the aar is supposed to look like?
troth
post Sep 5 2017, 08:03 AM
Have a 1975 1.8 with L-jet. It used to fire right up, but it sat in the driveway for a month or two. Now it takes a couple seconds of cranking and sometimes feathering the throttle a bit to get it to start when cold. Starts fine when hot.
I took a look at the AAR. Is this what the "open" position looks like on the AAR or should there be a bigger hole? There was a decent bit of moisture in there, but I couldn't see any corrosion.
troth
post Sep 8 2017, 03:54 PM
It's definitely the right part... part number checks out on PET. As far as I can tell it's working correctly, but is it letting enough air through when cold? Should the "slot" in the valve be more open?
Vacuum lines were replaced in the last year so other than the aar I don't know what could be causing the issue.
- Lo-Fi Version Time is now: 6th January 2025 - 05:04 PM
