nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
I recently adjusted my vales .06/.08 and also rebuilt my carbs. They were done separate and driven in between. I'm now noticing a pinging sound coming from the carb barrel on cylinder 3. If I put my hand over the carb throat it makes the sound go away. It is doing this at idle of ~950. I will load a video of the sound. What do you all think?
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Read this and thought the noise may be lean spitback from that cylinder,you mentioned putting your hand over the throat it go's away,by doing that it points to a lean condition in that cylinder,have you balanced the carbs and set the mixture screws correctly....just asking.
Valve setting and timing is it correct also ? Good luck. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:26 AM |
