Anyone running a Holley 4-barrel carb that can offer some help?, Need to figure out linkage setup for throttle |
Matty900 |
Sep 11 2017, 11:16 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
We've been killing ourselves trying to get this car ready to take to Okteenerfest. Had to swap out the carbs that we were going to use for a setup that is running off of a Corvair and Holley 4-barrel set up. But having a hard time with bad throttle cable and trying to figure out smooth linkage for this. Has anybody done this that can give me some pictures and show me the best way to do it?
Attached thumbnail(s) |
JRust |
Sep 11 2017, 02:04 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Looks like that is on a type 4? I don't think I have ever seen a holley 4 barrel on a 914 motor (IMG:style_emoticons/default/confused24.gif) . If your going to run carbs they need to be dual carbs. The single has never been a good setup as it leans out one side in hard cornering. If this isn't an air cooled motor please just ignore me (IMG:style_emoticons/default/idea.gif)
Andyrew |
Sep 11 2017, 09:49 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Looks like that is on a type 4? I don't think I have ever seen a holley 4 barrel on a 914 motor (IMG:style_emoticons/default/confused24.gif) . If your going to run carbs they need to be dual carbs. The single has never been a good setup as it leans out one side in hard cornering. If this isn't an air cooled motor please just ignore me (IMG:style_emoticons/default/idea.gif) Most def is a type 4... You can see the intake runners. Pretty common conversion that I personally have never seen run right. I think the intake runners simply are too long for a single carb. But the carb is in the same position as a V8 carb only about 6" lower. |
RRietman |
Sep 11 2017, 10:03 PM
Member Group: Members Posts: 100 Joined: 13-December 09 From: Pacific Northwest USA Member No.: 11,124 Region Association: None |
Looks like that is on a type 4? I don't think I have ever seen a holley 4 barrel on a 914 motor (IMG:style_emoticons/default/confused24.gif) . If your going to run carbs they need to be dual carbs. The single has never been a good setup as it leans out one side in hard cornering. If this isn't an air cooled motor please just ignore me (IMG:style_emoticons/default/idea.gif) Most def is a type 4... You can see the intake runners. Pretty common conversion that I personally have never seen run right. I think the intake runners simply are too long for a single carb. But the carb is in the same position as a V8 carb only about 6" lower. shit can that set up. if you can't afford IDF's get some used dellorto's. It will never run right. Randy |
Lo-Fi Version | Time is now: 26th June 2024 - 02:43 AM |
