First Welding Fire: close one!, dang near burned down my 14 on the lift |
Calwaterbear |
Sep 16 2017, 07:35 PM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
so I am welding sheet metal patches on the holes on my 72. I started thinking I had 6 holes, now I'm at 12, and will be rebuilding the bottom back 1/4th of the tunnel before I'm done with the welding.
Car is up on the lift, I'm welding between the rear of the pan, and the bottom of the firewall - Ironic , as it turned out. So my left shoulder is getting hot - that seems odd. I stop welding, and there seems to be more smoke than normal. Luckily, since i had already cut out the bottom of the tunnel, I happen to see flames inside the cabin - weird, I have it stripped, and just got done painting it. so now : shut down the welder, move it from under the lift, lift the lift a few inches, that allows me to pull the safety catch cables, then finally lower it down till I can see inside. full blown campfire on the floor. Turns out I had left a nylon bag fiull of my rags inside, as well as a roll of masking paper and they were fully engulfed. Threw on the welding blanket, shut it down pretty quick, but it shook me up a bit. I guess I'm done for the night. lesson learned, make sure i know whats on the other side of the weld, I'll be back at it tommorrow, remove and redo the interior paint on the passenger floor, then back to welding, wiser and more carefull! |
Lo-Fi Version | Time is now: 27th June 2024 - 07:17 PM |
