Electrical installation questions, Various issues under one thread |
JFG |
Sep 16 2017, 04:09 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I'm now in a position to test the electricals on my car. It came with many things missing & broken.
I'm running twin carbs so there'll be no injection specific issues with electrics. To start I have the following; Wiring up the reverse light switch. I have used separate bullet connectors (part of the missing category) but I don't know if there is a right/wrong way to insert them. For example, is there a way to look on the switch to see which is live/earth? There are 2 gauges where the lights don't illuminate. The rev counter and the multi gauge. The Speedo lights up fine. Bulbs and sockets are all new. When I turn the ignition on the passenger side headlight opens up halfway, does not illuminate until I pull the light switch and does not raise or lower from this position. Finally (for now) I only have one movement on the wiper switch. This came with the ignition cowl as a once piece lot. I'll post some pictures shortly. |
JFG |
Sep 17 2017, 08:50 AM
Looks like i need to pull the wiper motor to test, no relay in the circuit!
With a bit of a potch the brake pedal switch is fitted and working. The pictures below are of wires that i have "spare" any help with these. They're all up in the centre dash area. The picture below has the following; Black/blue stripe 11.04v only when main lights are on. no power all other times Grey/red stripe 0.22v only when main lights are on. No power all other times. Brown earth. Could it be a fog light switch wiring? Just the thin red & yellow in this pic. Red 12.02v switched live Yellow/ red stripe no power. |
Lo-Fi Version | Time is now: 26th December 2024 - 10:46 PM |
