Morrie |
Member ![]() ![]() Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region ![]() ![]() |
I am ready to route wiring from the engine bay to the cockpit for my AFR meter. I am curious about where folks have routed wires / drilled holes, etc. I know I want to stay away from ignition components based on experience, and it looks like the current wire harness access point is pretty much stuffed. The connector is for an Innovate MTX-L and the connector to feed through to the cockpit is probably 1/2 an inch long, so it is more than fishing a couple wires.....
Appreciate any experience based advice. The exhaust bung is welded in place so this is next on the agenda so I can start working on tuning the D-Jet setup. Kind regards, |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I used a coat hanger wire to thread more wires through the "snorkel" and alongside the main wiring harness.
--DD |
Morrie |
I used a coat hanger wire to thread more wires through the "snorkel" and alongside the main wiring harness. --DD That would be ideal. Not sure if I could make that work with the connector on the Innovate. I would have to push all the pins and reinstall on the other side without damaging anything. If it was a single or couple heavier gauge wires maybe. Good suggestion though!!! |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:47 PM |
