dax1969 |
Member ![]() ![]() Group: Members Posts: 367 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None ![]() ![]() |
Hi,
Sorry for double post in other thread (faster reply here in the garage) but need to know what brand of wheels the below are. Thought Riviera but the ones I found are with silver insert and not black. Also, do you know what kind of meter this is ? Oilpressure ? car = 1973 2.0 euro spec thks Dax ![]() ![]() |
dax1969 |
Thks Mark Henry. Those wheels are aftermarket and not original ? 1973 it should have babyfuchs rims ? The VDO meter is an oilpressure meter ? If it works what should it read ? Think you guys have PSI but I can see kg2/km... ??? This meter was never standard in a 914 euro spec ? Any idea out of which car it could come ? Sorry for asking but checking on a car tomorrow and want to be prepared krgds Dax |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Thks Mark Henry. Those wheels are aftermarket and not original ? 1973 it should have babyfuchs rims ? The VDO meter is an oilpressure meter ? If it works what should it read ? Think you guys have PSI but I can see kg2/km... ??? This meter was never standard in a 914 euro spec ? Any idea out of which car it could come ? Sorry for asking but checking on a car tomorrow and want to be prepared krgds Dax the Kp is kilopascal and = to .01 bar. not sure about the km, doesn't make sense. 1 bar=14.5 psi, so I'm guessing it's just reading in bar units. |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
the Kp is kilopascal and = to .01 bar. not sure about the km, doesn't make sense. 1 bar=14.5 psi, so I'm guessing it's just reading in bar units. Looks like kiloPascals per square centimeter. That and the OEL below make me think it is indeed an oil pressure gauge. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
the Kp is kilopascal and = to .01 bar. not sure about the km, doesn't make sense. 1 bar=14.5 psi, so I'm guessing it's just reading in bar units. Looks like kiloPascals per square centimeter. That and the OEL below make me think it is indeed an oil pressure gauge. Wrong.......Americans (IMG:style_emoticons/default/rolleyes.gif) .....tisk-tisk (IMG:style_emoticons/default/slap.gif) You should have embraced the metric system. (IMG:style_emoticons/default/shades.gif) I can't read it but it's likeley it's kgf/cm^, other clue is it only goes up to 5. kilopascale = .14 psi kilogram/cm^ =14.2 psi |
twistedstang |
Member ![]() ![]() Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None ![]() ![]() |
QUOTE Wrong.......Americans (IMG:style_emoticons/default/rolleyes.gif) .....tisk-tisk (IMG:style_emoticons/default/slap.gif) You should have embraced the metric system. (IMG:style_emoticons/default/shades.gif) I can't read it but it's likeley it's kgf/cm^, other clue is it only goes up to 5. kilopascale = .14 psi kilogram/cm^ =14.2 psi Just remember. There are two kinds of countries in this world. Those that use the metric system, and those that have been to the moon. (IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 03:19 AM |
