> Electrical installation questions, Various issues under one thread
JFG
post Sep 16 2017, 04:09 AM
I'm now in a position to test the electricals on my car. It came with many things missing & broken.
I'm running twin carbs so there'll be no injection specific issues with electrics.
To start I have the following;
Wiring up the reverse light switch. I have used separate bullet connectors (part of the missing category) but I don't know if there is a right/wrong way to insert them. For example, is there a way to look on the switch to see which is live/earth?
There are 2 gauges where the lights don't illuminate. The rev counter and the multi gauge. The Speedo lights up fine. Bulbs and sockets are all new.
When I turn the ignition on the passenger side headlight opens up halfway, does not illuminate until I pull the light switch and does not raise or lower from this position.
Finally (for now) I only have one movement on the wiper switch. This came with the ignition cowl as a once piece lot.
I'll post some pictures shortly.
Dave_Darling
post Sep 23 2017, 11:06 PM
914 Idiot
All of those spades are connected together, so you should be able to hook the wire to any of them.
Double-check that there is zero resistance between the various spades, though, in case I'm wrong... (IMG:style_emoticons/default/biggrin.gif)
--DD
- Lo-Fi Version Time is now: 26th December 2024 - 10:29 PM
