jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,167 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
Big adventure for me. Have never done this before by myself. Taking the engine out of my 70 914-6.
I got everything, I think, disconnected and/or removed today -- except the half shafts. My memory is failing me. 5-10 years ago, I bought and installed bolts that were drilled for safety wires, which I did. Now I can't remember if they were 6mm Allen, which seems to fit if I can get it squarely in, or was there a spline fitting? I found a single spline thing with my Allen sockets that is just about the same size, perhaps 8. Something tells me it might have been purchased for those bolts. I can get the 6mm in there, but I am not sure that is it and I don't want to round the inside of the fastener. The spline thing may be too big or I may not have it square. Scared to pound it in. The bolts are tight. Aren't they always? They got a dose of pbBlaster for the night. I'll finish this tomorrow, I hope. Are the OEM bolts 6mm? Did anyone here install the drilled bolts and can you tell me, Allen or spline? What size? Any tricks getting them loose? A universal with an extension? (I just have headers) Use an impact wrench? I must have done this part of the job before, but the memory thing . . . I seem to recall torque wrenching them, too. What should they be torqued to? Thanks in advance. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,812 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Stock 914 4 and 6 CV bolts are 12 point triple square allen, so you need to clean them off and get a close look. If you use a 6 point allen you'll strip them.
I clean them really good and tap them in the socket before leaning on them. If you don't seat it in the socket, you can strip it. |
Lo-Fi Version | Time is now: 19th April 2025 - 06:39 PM |
