> Engine Removal, Half Shafts
jfort
post Sep 24 2017, 01:56 PM
Big adventure for me. Have never done this before by myself. Taking the engine out of my 70 914-6.
I got everything, I think, disconnected and/or removed today -- except the half shafts. My memory is failing me. 5-10 years ago, I bought and installed bolts that were drilled for safety wires, which I did. Now I can't remember if they were 6mm Allen, which seems to fit if I can get it squarely in, or was there a spline fitting? I found a single spline thing with my Allen sockets that is just about the same size, perhaps 8. Something tells me it might have been purchased for those bolts. I can get the 6mm in there, but I am not sure that is it and I don't want to round the inside of the fastener. The spline thing may be too big or I may not have it square. Scared to pound it in.
The bolts are tight. Aren't they always? They got a dose of pbBlaster for the night. I'll finish this tomorrow, I hope.
Are the OEM bolts 6mm? Did anyone here install the drilled bolts and can you tell me, Allen or spline? What size? Any tricks getting them loose? A universal with an extension? (I just have headers) Use an impact wrench? I must have done this part of the job before, but the memory thing . . .
I seem to recall torque wrenching them, too. What should they be torqued to?
Thanks in advance.
IronHillRestorations
post Sep 24 2017, 02:18 PM
I. I. R. C.
Stock 914 4 and 6 CV bolts are 12 point triple square allen, so you need to clean them off and get a close look. If you use a 6 point allen you'll strip them.
I clean them really good and tap them in the socket before leaning on them. If you don't seat it in the socket, you can strip it.
Mark Henry
post Sep 24 2017, 08:29 PM
that's what I do!
QUOTE(Perry Kiehl @ Sep 24 2017, 04:18 PM) *
(IMG:style_emoticons/default/agree.gif) Like Totally (IMG:style_emoticons/default/biggrin.gif)
Whole secret to these bolts, the right bit and clean out all the crap in the hole.
jfort   Engine Removal   Sep 24 2017, 01:56 PM
Perry Kiehl   Stock 914 4 and 6 CV bolts are 12 point triple squ...   Sep 24 2017, 02:18 PM
Mark Henry   Stock 914 4 and 6 CV bolts are 12 point triple sq...   Sep 24 2017, 08:29 PM
Lucky9146   Stock 914 4 and 6 CV bolts are 12 point triple sq...   Sep 26 2017, 03:27 PM
mobymutt   I used an extension (no universal) to get the sock...   Sep 24 2017, 02:34 PM
Dave_Darling   Stock is M8 "triple square". Allen-head...   Sep 24 2017, 02:48 PM
mepstein   If you used 911 cv’s, they are 6mm   Sep 24 2017, 05:12 PM
Larmo63   These only get torqued to 18.4 ft.lbs, so they sho...   Sep 24 2017, 06:12 PM
jfort   Thanks guys. I'll try to inspect them more clo...   Sep 24 2017, 07:17 PM
Perry Kiehl   Also, you need new schnoor washers everytime you t...   Sep 24 2017, 08:25 PM
falcor75   First time I loosened my driveshafts on the 914 I ...   Sep 25 2017, 12:42 AM
76-914   I clean them really good and tap them in the soc...   Sep 25 2017, 04:41 PM
Mark Henry   8mm =31 ft/lb 10mm =55 ft/lb It's a special h...   Sep 25 2017, 05:00 PM
porschetub   8mm =31 ft/lb 10mm =55 ft/lb It's a special ...   Sep 26 2017, 01:55 PM
Lucky9146   8mm =31 ft/lb 10mm =55 ft/lb It's a special...   Sep 26 2017, 03:29 PM
Perry Kiehl   [quote name='porschetub' post='2531585' date='Sep...   Sep 26 2017, 04:19 PM
porschetub   [quote name='porschetub' post='2531585' date='Sep...   Sep 26 2017, 09:11 PM
Perry Kiehl   If you've only torqued them to 18.4 Lawrence, ...   Sep 25 2017, 06:06 PM
jfort   Thanks for all the input. Last night I confirmed t...   Sep 26 2017, 09:02 AM
rjames   Some of the ones that were drilled for safety wire...   Sep 26 2017, 10:27 AM
Vacca Rabite   If the bolts are drilled for safety wire, they lik...   Sep 26 2017, 11:08 AM
Larmo63   Oops, yes, 31 ft.lbs. I did torque mine correctly...   Sep 26 2017, 12:13 PM
Lucky9146   Wow this is a great thread and extremely timely fo...   Sep 26 2017, 12:45 PM
Andyrew   I hate getting the bolts on the trailing arm side ...   Sep 26 2017, 01:53 PM
jfort   I had trouble getting the Schnorr CV joint bolt wa...   Oct 18 2017, 08:53 AM
11tenths   When I removed my CVs I found the PO had used some...   Oct 18 2017, 10:17 AM
altitude411   re: Schnoor washers- Which way is the correct...   Oct 18 2017, 11:11 AM
Dr Evil   My $0.02 I don't use gaskets anymore and...   Oct 18 2017, 10:59 AM
rjames   My $0.02 I don't use gaskets anymore an...   Oct 18 2017, 01:36 PM
Andyrew   I havent used a gasket in years either. I dont eve...   Oct 18 2017, 02:38 PM
jfort   posted to the wrong thread. sorry. see engine buil...   Dec 6 2017, 12:42 PM
Mark Henry   What's the plan wheels, brakes, etc? Are you g...   Dec 6 2017, 02:04 PM
- Lo-Fi Version Time is now: 19th April 2025 - 06:39 PM
