jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,167 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
Big adventure for me. Have never done this before by myself. Taking the engine out of my 70 914-6.
I got everything, I think, disconnected and/or removed today -- except the half shafts. My memory is failing me. 5-10 years ago, I bought and installed bolts that were drilled for safety wires, which I did. Now I can't remember if they were 6mm Allen, which seems to fit if I can get it squarely in, or was there a spline fitting? I found a single spline thing with my Allen sockets that is just about the same size, perhaps 8. Something tells me it might have been purchased for those bolts. I can get the 6mm in there, but I am not sure that is it and I don't want to round the inside of the fastener. The spline thing may be too big or I may not have it square. Scared to pound it in. The bolts are tight. Aren't they always? They got a dose of pbBlaster for the night. I'll finish this tomorrow, I hope. Are the OEM bolts 6mm? Did anyone here install the drilled bolts and can you tell me, Allen or spline? What size? Any tricks getting them loose? A universal with an extension? (I just have headers) Use an impact wrench? I must have done this part of the job before, but the memory thing . . . I seem to recall torque wrenching them, too. What should they be torqued to? Thanks in advance. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
8mm =31 ft/lb
10mm =55 ft/lb It's a special hardness bolt. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,790 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Lucky9146 |
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,676 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California ![]() ![]() |
8mm =31 ft/lb 10mm =55 ft/lb It's a special hardness bolt. High tensile 12.9 from memory,I snuck mine up to 32ft/lbs ,they can take it no problem. Make sure the joining faces are nice and clean,I didn't use gaskets as I didn't have them ...ok so far. I don't have gaskets and was suppose to get them today but have not heard from the guy. Anybody else run without gaskets? Essential or not? |
Lo-Fi Version | Time is now: 19th April 2025 - 06:45 PM |
