> Easy as 1 2 3, Got it yesterday, pushed all projects aside!
mgphoto
post Sep 28 2017, 03:54 PM
"If there is a mistake it will find me"
Got the 123Ignition yesterday, I pushed all of my projects back!
"Sorry granny I'll get to those bearings on your heart/lung machine soon, I promise."
Blocked out 3 hours for the removal and install.
Added about an hour to charge the battery.
Installed as expected, there is a spacer that is necessary for type 4, just slides over the dizzy shaft.
I decided to route the wires and vacuum away from the fan so access to the vacuum nipple was easier, since the vacuum can is gone there's a lot more space.
Followed the instructions but made the mistake of using the TDC 0* instead of the 27* as the basic timing point. I just walked the dizzy CCW until she started!
Didn't do anything other than matched my timing with my idle, I let her run till she settled down.
Just around the block once, ha ha the trailer hitching is GONE!
Responsive throttle, man!
Setting up a tuning session, nice 150 mile run up the California coast with the AFR meter.
Mike
Porschef
post Sep 28 2017, 05:10 PM
How you doin'
What was the distributor that you replaced with the 123?
mgphoto   Easy as 1 2 3   Sep 28 2017, 03:54 PM
76-914   Got the 123Ignition yesterday, I pushed all of my...   Sep 28 2017, 04:26 PM
Porschef   What was the distributor that you replaced with th...   Sep 28 2017, 05:10 PM
mgphoto   What was the distributor that you replaced with t...   Sep 28 2017, 05:32 PM
Montreal914   Nice! What's your engine, induction system...   Sep 29 2017, 08:26 AM
mgphoto   Nice! What's your engine, induction syste...   Sep 29 2017, 11:33 AM
Mblizzard   Really liked my 1 2 3. Did you get the programmab...   Sep 29 2017, 10:50 AM
mgphoto   Really liked my 1 2 3. Did you get the programma...   Sep 30 2017, 01:40 PM
914_teener   Really liked my 1 2 3. Did you get the programm...   Sep 30 2017, 02:13 PM
StratPlayer   Been running my 123 dist. for about a year now, mo...   Sep 29 2017, 07:24 PM
pete000   This has been on my want list for a while now. W...   Sep 29 2017, 08:49 PM
mgphoto   This has been on my want list for a while now. ...   Sep 30 2017, 01:37 PM
Porschef   :popcorn: :popcorn: :idea:   Sep 30 2017, 05:05 AM
StratPlayer   I bought mine from the manufacturer.   Sep 30 2017, 12:07 PM
mgphoto   Now for the ugly. I am Sorry, I am SORRY, I AM SO...   Sep 30 2017, 02:25 PM
pete000   Mine likes to run around 210 on the oil...   Sep 30 2017, 05:46 PM
Porschef   :popcorn: :popcorn: :rolleyes:   Oct 1 2017, 10:12 AM
mgphoto   OK so I am going through the ignition wiring, the ...   Oct 2 2017, 04:30 PM
cuddyk   Maybe a coil that's on its way out? Mine behav...   Oct 2 2017, 05:31 PM
123ignitionusa   Maybe a coil that's on its way out? Mine beha...   Nov 6 2017, 04:22 PM
Vacca Rabite   Ive got the 123 for my Bmw2002. I have yet to put...   Oct 3 2017, 10:31 AM
JoeD   Also been running a 123 on my 2270 dual-carbed Rab...   Oct 3 2017, 01:37 PM
mgphoto   So the miss I find is a loose injector connector, ...   Oct 24 2017, 11:36 AM
BeatNavy   Cool, thanks for the pictures. So now I know it...   Oct 24 2017, 12:59 PM
mgphoto   Cool, thanks for the pictures. So now I know it...   Oct 24 2017, 01:58 PM
Vacca Rabite   Sounds like you are well on the way. I hate electr...   Oct 24 2017, 12:10 PM
mgphoto   We all have a need to see.   Oct 24 2017, 12:26 PM
mgphoto   Don't know why they are 90* off in the post bu...   Oct 24 2017, 12:31 PM
mgphoto   FYI type 4 needs a spacer which should come with t...   Oct 24 2017, 12:34 PM
mgphoto   I took her out for an early spin on Saturday, 68*F...   Oct 30 2017, 12:15 PM
Mblizzard   I took her out for an early spin on Saturday, 68*...   Oct 30 2017, 01:42 PM
mgphoto   I took her out for an early spin on Saturday, 68...   Oct 30 2017, 02:07 PM
pete000   If the car did not ping with the stock distributor...   Oct 30 2017, 02:13 PM
914_teener   If the car did not ping with the stock distributo...   Oct 30 2017, 09:23 PM
mgphoto   If the car did not ping with the stock distributo...   Oct 31 2017, 10:45 AM
Rand   Early spark is the most common cause. Cylinder pr...   Oct 30 2017, 02:27 PM
Philip W.   i agree that your timing has to be off but also yo...   Oct 30 2017, 07:53 PM
mepstein   Our cars run on regular fuel. Unless modified, the...   Oct 30 2017, 08:20 PM
Rand   When you change a part that affects timing and you...   Oct 30 2017, 08:29 PM
mgphoto   I Rebuilt this dizzy when I built the motor about ...   Oct 31 2017, 10:49 AM
mgphoto   Ok this engine is not stock. J&E forged ...   Oct 31 2017, 11:16 AM
Mblizzard   Not sure this is helpful but attached is the curve...   Oct 31 2017, 12:57 PM
mgphoto   Ok nothing has changed, I did nothing to the car e...   Oct 31 2017, 03:07 PM
KELTY360   Ok nothing has changed, I did nothing to the car ...   Nov 6 2017, 05:51 PM
BeatNavy   I just ordered a new Bosch (Blue) coil, new plugs,...   Nov 6 2017, 05:51 PM
mgphoto   about 3 gallon of techron 91 left in the tank, too...   Nov 7 2017, 09:58 AM
mgphoto   Running on the last 2 gallons of the Chevron, I de...   Nov 13 2017, 03:37 PM
- Lo-Fi Version Time is now: 6th January 2025 - 09:55 PM
