jesse7flying |
Member ![]() ![]() Group: Members Posts: 134 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None ![]() ![]() |
I've tried doing some research so I wouldn't ask too many stupid questions, but here goes. I acquired a 1.8L engine that had dropped a valve. My plan is to upgrade the guts to make a 2056 out of it. I've bought a 2.0L crank and rods (thks Dominic) to put in the "new" engine as recommended by Jake Raby in some older posts. The thing Raby does not address (unless I missed it, very possible) is what do I do about a cam? It seems like Raby's default position is to use carbs, but I would like to go with the FI system. Does that mean that I need to source a FI system from a 2.0L motor including the MPS, AFR, ECU, injectors, etc, or is anything off a 1.7 or 1.8L motor usable in this case? Once I have a list of items to buy, I will place a WTB ad in the forum, but any suggestions to point me in the right direction would be very much appreciated.
Regards--Jesse BTW, I did not mention that I'm trying to do this upgrade as cheaply as I can, but I don't want to be stupid about it, lol. |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I just upgraded my ‘75 L-Jet to 96mm P/C’s with 2L crank. The TB was also replaced with the larger Vanagon 2.1 TB - a direct fit. Also use a Mallory Unilite distributed (NLA)
The only thing I didn’t do (yet) is to install the Tangerine exhaust |
Lo-Fi Version | Time is now: 26th June 2024 - 11:31 AM |
