cal44 |
Member ![]() ![]() Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region ![]() ![]() |
Lads,
Not being fully versed on everything VW, I was curious if the a 2.0 Bus engine and a 2.0 914 engine are the same......Or, will a Bus 2.0 bolt right into a 914. Air cooled of course. Also 1.7 and 1.8 while you are at it. Thanks bunch. Mike Sarcastic remarks welcome, I like the humor |
DM_2000 |
Member ![]() ![]() Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None ![]() |
T1 into early 912
http://www.shoptalkforums.com/viewtopic.php?t=32894 There were also some threads about a Porsche trans in a T1 Bug that I can find again at the moment. A T4 capable manual trans has a longer pilot on the input shaft than the T1, this would need to be addressed. Summit is showing fully assembled long block zero mile 2275 and 2332 T1 engines for $ 3,300 and $ 3,400, ( This is less tin, cooling , flywheel / clutch, fuel , ignition ) I didn't look at HP though. Engine kits are here. http://www.scatvw.com/engine-kits ( $ 3,000 ) Nitrided chromoly forged crankshaft NEW SCAT forged H-Beam rods (Chevy or VW journal) NEW Stroker AS41 dual by-pass engine case NEW ‘D Port’ polished dual-port heads NEW 3/8″ cut to length chromoly pushrods NEW Crankshaft Gear Assembly Kit #10207 NEW 40-piece Engine Lock Nut Kit #10173 NEW Universal Engine Case Hardware Kit # 10205 NEW SCAT adjustable O-Ring aluminum pushrod tubes NEW 4140 chromoly 8mm dual-port cylinder/head stud kit http://www.scatvw.com/engine-kits |
Lo-Fi Version | Time is now: 26th June 2024 - 11:23 AM |
