jesse7flying |
Member ![]() ![]() Group: Members Posts: 134 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None ![]() ![]() |
I've tried doing some research so I wouldn't ask too many stupid questions, but here goes. I acquired a 1.8L engine that had dropped a valve. My plan is to upgrade the guts to make a 2056 out of it. I've bought a 2.0L crank and rods (thks Dominic) to put in the "new" engine as recommended by Jake Raby in some older posts. The thing Raby does not address (unless I missed it, very possible) is what do I do about a cam? It seems like Raby's default position is to use carbs, but I would like to go with the FI system. Does that mean that I need to source a FI system from a 2.0L motor including the MPS, AFR, ECU, injectors, etc, or is anything off a 1.7 or 1.8L motor usable in this case? Once I have a list of items to buy, I will place a WTB ad in the forum, but any suggestions to point me in the right direction would be very much appreciated.
Regards--Jesse BTW, I did not mention that I'm trying to do this upgrade as cheaply as I can, but I don't want to be stupid about it, lol. |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Either system is fine.
They just work differently. Whatever you decide, either learn as much as you can about either or find someone that does. The former is probably the path of least resistance. Get or get a hold of an AFM meter when you are ready tp tune it after break in. |
Lo-Fi Version | Time is now: 26th June 2024 - 11:29 AM |
