jesse7flying |
Member ![]() ![]() Group: Members Posts: 134 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None ![]() ![]() |
I've tried doing some research so I wouldn't ask too many stupid questions, but here goes. I acquired a 1.8L engine that had dropped a valve. My plan is to upgrade the guts to make a 2056 out of it. I've bought a 2.0L crank and rods (thks Dominic) to put in the "new" engine as recommended by Jake Raby in some older posts. The thing Raby does not address (unless I missed it, very possible) is what do I do about a cam? It seems like Raby's default position is to use carbs, but I would like to go with the FI system. Does that mean that I need to source a FI system from a 2.0L motor including the MPS, AFR, ECU, injectors, etc, or is anything off a 1.7 or 1.8L motor usable in this case? Once I have a list of items to buy, I will place a WTB ad in the forum, but any suggestions to point me in the right direction would be very much appreciated.
Regards--Jesse BTW, I did not mention that I'm trying to do this upgrade as cheaply as I can, but I don't want to be stupid about it, lol. |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I just upgraded my ‘75 L-Jet to 96mm P/C’s with 2L crank. The TB was also replaced with the larger Vanagon 2.1 TB - a direct fit. Also use a Mallory Unilite distributed (NLA)
The only thing I didn’t do (yet) is to install the Tangerine exhaust |
jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
I just upgraded my ‘75 L-Jet to 96mm P/C’s with 2L crank. The TB was also replaced with the larger Vanagon 2.1 TB - a direct fit. Also use a Mallory Unilite distributed (NLA) The only thing I didn’t do (yet) is to install the Tangerine exhaust what cam are you running. I thought any mods to the cam, pistons, etc, meant going to carbs? |
jim_hoyland |
I just upgraded my ‘75 L-Jet to 96mm P/C’s with 2L crank. The TB was also replaced with the larger Vanagon 2.1 TB - a direct fit. Also use a Mallory Unilite distributed (NLA) The only thing I didn’t do (yet) is to install the Tangerine exhaust what cam are you running. I thought any mods to the cam, pistons, etc, meant going to carbs? I believe it’s a stock cam; it wasn’t changed with the recent upgraded. But about 15 years ago the Motor was rebuilt and it might have been replaced. In any case the car feels very strong and the engine runs very smooth in all conditions |
Lo-Fi Version | Time is now: 26th June 2024 - 11:31 AM |
