> need some pre-painting advice, how much prep is required on "hidden" parts?
914 RZ-1
post Sep 30 2017, 03:10 PM
Porsche Padawan
I've decided I want to paint my car myself. I'm not going for some award-winning concourse-quality car with a $10,000 paint job, just something that looks better than the beater I currently have. The car was in an accident long ago and repaired well, but it's not 100% perfect, so it doesn't make sense to me to spend tons of money on it. I'd rather drive it and enjoy it. That said, it's still a nice car and runs great and looks good.
I plan to spend most of my time finishing the parts of the car that will show and less time on the parts that are usually hidden: under the hoods, the door jambs, inside the trunks, etc.
What's the minimum I would need to do to get these surfaces ready for paint? Scuff with Scotch-Brite? Sand with 220 or some other grit? Sand blast? Is it better to use power tools or do it by hand?
The car was originally metallic silver. It is currently white (engine bay, area by fuel tank are still silver). I plan to paint it a solid (not metallic) gray that closely matches the silver.
IronHillRestorations
post Sep 30 2017, 04:08 PM
I. I. R. C.
Wash with soap and water. TSP works really well, but it will take the finish off paint you might not want to get damaged, but I like it. Get everything really clean with soap and water first.
Wipe everything with Prepsol, Klix88 or some kind of cleaner, wax remover solvent. Apply solvent with clean rag, wipe off with clean rags, and change wipe rags so you aren't spreading around contaminants.
If you don't get all the grease, oil, wax, silicones, and contaminates off the surfaces you'll have paint adhesion problems. You can't over clean.
A lot of shops use red scotch brite pads for inside the trunks and difficult areas to prep for paint. It's worked good for me.
Wipe off sanded areas and paint with the same solvent and more clean rags.
Epoxy primer sticks really well to properly prepared surfaces, but you want to top coat it within the recommended time window.
- Lo-Fi Version Time is now: 22nd September 2026 - 07:04 AM
