> Electrical installation questions, Various issues under one thread
JFG
post Sep 16 2017, 04:09 AM
I'm now in a position to test the electricals on my car. It came with many things missing & broken.
I'm running twin carbs so there'll be no injection specific issues with electrics.
To start I have the following;
Wiring up the reverse light switch. I have used separate bullet connectors (part of the missing category) but I don't know if there is a right/wrong way to insert them. For example, is there a way to look on the switch to see which is live/earth?
There are 2 gauges where the lights don't illuminate. The rev counter and the multi gauge. The Speedo lights up fine. Bulbs and sockets are all new.
When I turn the ignition on the passenger side headlight opens up halfway, does not illuminate until I pull the light switch and does not raise or lower from this position.
Finally (for now) I only have one movement on the wiper switch. This came with the ignition cowl as a once piece lot.
I'll post some pictures shortly.
JFG
post Oct 1 2017, 11:06 AM
I started the engine for the first time today (IMG:style_emoticons/default/biggrin.gif) seems ok but need to bring the timing in when I get the strobe and pull the plugs to check the mixture.
When it was running I checked the charge across the battery. It read 13.35v. is this about right? I fitted a new alternator 55amp iirc. The relay board was bought used and unknown condition with a regulator attached.
Lastly, I've tried the passenger headlight again and although everything is now lined up correctly it will not raise electronically. It will lower electronically. When I first fitted it I got the fittings in the wrong place and the light would lift halfway.
Any ideas? I've swapped the relays and it makes no difference.
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 10:54 PM
