> Distributor Problems, Missing on Cylinder #4
warrenoliver
post Oct 1 2017, 05:31 PM
I just returned from a long weekend trip with some other PCA members. The weather was beautiful and we had a great time. My car did not cooperate. I have a 73, 2.0 with FI and Pertronix Ignitor ignition. I have had the Pertronix ignition for a couple of years now and I have had no problems. The problem I am having with the car is that initially it runs great while the engine is cold and while it is warming up. Once it is warmed up - about 7-10 miles, on country roads, it begins missing badly. The miss is not consistent and seems to get better on acceleration. When I come to a stop, the engine idles very slow (200-400 rpm) and sounds like a John Deere tractor.
I put a timing light on each of the spark plug wires and found cylinder #4 is misfiring badly. I thought maybe the wire was bad so I switched it with another cylinder and found that #4 was still missing. I had an old distributor cap and put that on thinking maybe it was a cracked distributor cap. The problem stays with cylinder #4 with both caps.
I am now thinking it must be either the rotor or the electronic ignition module. Tomorrow I will try a different rotor.
My question is: Does this sound like the electronic module is going bad? When they go bad, do they cause this intermittent miss? Any other ideas out there?
Thanks.
Warrenoliver
Dave_Darling
post Oct 1 2017, 07:21 PM
914 Idiot
Also check the plug.
--DD
warrenoliver
post Oct 1 2017, 07:33 PM
QUOTE(Dave_Darling @ Oct 1 2017, 08:21 PM) *
--DD
Dave,
I didn't think of checking the plug itself - I will check it in the morning. If the plug is bad, wouldn't there still be power coming down the plug wire as shown by my test light? When it is idling and missing badly, I can see the light pauses occasionally.
- Lo-Fi Version Time is now: 28th December 2024 - 04:25 AM
