arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 776 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
Car is ‘73 2.0 with stock d-jet. Has been running fine, just passed a PPI last Thursday. Late yesterday afternoon I started it to move it. Started fine, ran normally for 15-20 seconds, then quit suddenly. No sputter, just quit as if the ignition was switched off. Since then it will crank over normally, but no fire. Occasionally a very weak cough, but generally not even that.
I immediately checked for spark, and that is good all the way to the plugs. So it is fuel related. I’ve got fuel pressure, the pump runs it’s brief priming bit when the ignition is switched on, and appears to run while the engine is cranking. The sudden nature of the failure leads me to think it is electrical, not fuel supply as such. Also doesn’t sound like trigger points, if I understand those right it seems unlikely that both sides would fail simultaneously. I’m leaning toward a bad wire or connector of some sort, or possibly a D-jet component that has failed electrically. Any suggestions on likely causes are welcome! |
arne |
Appears to be no fuel, or perhaps insufficient fuel. Plugs are dry, no fuel smell in the exhaust.
Relay board sounds like it could cause this issue, but I don't have a spare to swap in. |
Lo-Fi Version | Time is now: 19th April 2025 - 02:48 AM |
