Testing oil pressure and head temp sensors, need help from electrical gurus! |
mobymutt |
Oct 1 2017, 05:15 PM
Senior Member Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Trying a new thread, with less words, since my last one was ignored. (IMG:style_emoticons/default/chair.gif)
How do I test the stock oil pressure and head temp sensors to see if they work? They aren't wired to anything, and I don't have gauges for them. Thanks! Matt |
troth |
Oct 1 2017, 07:47 PM
Member Group: Members Posts: 155 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
The oil pressure sensor I don't think would have a spec for resistance because it is a switch. It will either have an infinite or very small resistance reading depending on whether you have low pressure or not.
With ignition off (low pressure), you should have close to 0 resistance. If you switch ignition on but don't start the car, idiot light should come on. If you start the car and let oil pressurize for a second and then read again you should have a very high resistance and light will be off. |
Dave_Darling |
Oct 2 2017, 01:08 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Lo-Fi Version | Time is now: 28th December 2024 - 02:01 AM |
