> Distributor Problems, Missing on Cylinder #4
warrenoliver
post Oct 1 2017, 05:31 PM
I just returned from a long weekend trip with some other PCA members. The weather was beautiful and we had a great time. My car did not cooperate. I have a 73, 2.0 with FI and Pertronix Ignitor ignition. I have had the Pertronix ignition for a couple of years now and I have had no problems. The problem I am having with the car is that initially it runs great while the engine is cold and while it is warming up. Once it is warmed up - about 7-10 miles, on country roads, it begins missing badly. The miss is not consistent and seems to get better on acceleration. When I come to a stop, the engine idles very slow (200-400 rpm) and sounds like a John Deere tractor.
I put a timing light on each of the spark plug wires and found cylinder #4 is misfiring badly. I thought maybe the wire was bad so I switched it with another cylinder and found that #4 was still missing. I had an old distributor cap and put that on thinking maybe it was a cracked distributor cap. The problem stays with cylinder #4 with both caps.
I am now thinking it must be either the rotor or the electronic ignition module. Tomorrow I will try a different rotor.
My question is: Does this sound like the electronic module is going bad? When they go bad, do they cause this intermittent miss? Any other ideas out there?
Thanks.
Warrenoliver
Mblizzard
post Oct 1 2017, 07:13 PM
Typically the electronic ignitions are all or nothing (1 or 0). I had a similar problem and it was the magnet on the shaft had moved up somehow. Check that and the gap between the magnet and sensor.
warrenoliver
post Oct 1 2017, 07:30 PM
QUOTE(Mblizzard @ Oct 1 2017, 08:13 PM) *
I lost the little plastic feeler gauge that came with the ignition module. Do you know what kind of a gap it needs?
mgphoto
post Oct 2 2017, 03:57 PM
"If there is a mistake it will find me"
QUOTE(warrenoliver @ Oct 1 2017, 06:30 PM) *
just needs to be an air gap, thickness of the tip of a flat blade screwdriver.
- Lo-Fi Version Time is now: 28th December 2024 - 04:56 AM
