> Another no-start situation, 2.0 d-jet, Fixed! Dirty trigger points!
arne
post Oct 2 2017, 10:35 AM
Serial Rescuer of old vehicles...
Car is ‘73 2.0 with stock d-jet. Has been running fine, just passed a PPI last Thursday. Late yesterday afternoon I started it to move it. Started fine, ran normally for 15-20 seconds, then quit suddenly. No sputter, just quit as if the ignition was switched off. Since then it will crank over normally, but no fire. Occasionally a very weak cough, but generally not even that.
I immediately checked for spark, and that is good all the way to the plugs. So it is fuel related.
I’ve got fuel pressure, the pump runs it’s brief priming bit when the ignition is switched on, and appears to run while the engine is cranking.
The sudden nature of the failure leads me to think it is electrical, not fuel supply as such. Also doesn’t sound like trigger points, if I understand those right it seems unlikely that both sides would fail simultaneously.
I’m leaning toward a bad wire or connector of some sort, or possibly a D-jet component that has failed electrically.
Any suggestions on likely causes are welcome!
arne
post Oct 2 2017, 05:35 PM
Trigger points are in the distributor, but totally separate from the ignition circuit. They connect to the injection brain only. If they are bad, ignition continues normally but the injection is dead.
arne   Another no-start situation, 2.0 d-jet   Oct 2 2017, 10:35 AM
mepstein   When that happened to me, it was the relay panel i...   Oct 2 2017, 10:44 AM
BeatNavy   Assuming you have confirmed spark, you're prob...   Oct 2 2017, 10:45 AM
arne   Appears to be no fuel, or perhaps insufficient fue...   Oct 2 2017, 11:06 AM
arne   Removed relay board, metered out every terminal. A...   Oct 2 2017, 12:25 PM
BK911   Quick two step test to determine fuel or spark: 1....   Oct 2 2017, 12:49 PM
arne   Quick two step test to determine fuel or spark: 1...   Oct 2 2017, 12:54 PM
Dave_Darling   Check the electrical connections in the engine bay...   Oct 2 2017, 12:56 PM
76-914   Check the electrical connections in the engine ba...   Oct 2 2017, 01:32 PM
mgphoto   Gang of ground wires under the plenum, all FI grou...   Oct 2 2017, 01:02 PM
euro911   If you are hearing the pump running, sounds like y...   Oct 2 2017, 01:22 PM
Perry Kiehl   One of my stock questions on FI trouble is trigger...   Oct 2 2017, 01:46 PM
arne   One of my stock questions on FI trouble is trigger...   Oct 2 2017, 01:53 PM
JOEPROPER   It's always the last thing you check... :toke:   Oct 2 2017, 03:33 PM
arne   It's always the last thing you check... :toke:...   Oct 2 2017, 03:59 PM
euro911   Glad to hear ... :thumbsup:   Oct 2 2017, 05:10 PM
Rand   Thanks for sharing the solution! :trophy: Q. ...   Oct 2 2017, 05:23 PM
arne   Trigger points are in the distributor, but totally...   Oct 2 2017, 05:35 PM
Rand   Trigger points are in the distributor, but totall...   Oct 2 2017, 05:37 PM
arne   Trigger points are in the distributor, but totally...   Oct 2 2017, 06:23 PM
- Lo-Fi Version Time is now: 19th April 2025 - 02:50 AM
