GB late side shifter bushings and bellow all for $20, Need 10 takers to make this happen |
Mikey914 |
Sep 23 2017, 12:15 AM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Package for ALL the late side shifter bushings for $20
1 -911.424.139.00 ball cup http://shop.914rubber.com/91142413900-Ball...91142413900.htm 1-914.424.224.02 trans mount bushing http://shop.914rubber.com/Late-side-shifte...91442422402.htm 1-914.424.224.03 firewall bushing http://shop.914rubber.com/91442422403-late...91442422403.htm 1- 91442423902 side shift bellows http://shop.914rubber.com/914-late-side-sh...p3plqscsfapp006 2-911 424 223 03 shift knuckle bushings http://shop.914rubber.com/searchquick-subm...eywords=Knuckle I'll also offer the ability to add the cover and band for another $20 if you add to the GB $40 total) Only catch need 10 takers for a GB. I'll post up a thread. Mark Attached thumbnail(s) Attached image(s) |
87m491 |
Oct 3 2017, 06:48 AM
Member Group: Members Posts: 326 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Hi Mike,
I am having trouble catching up on these GB's. I am on 914world only occasionally and it seems luck when I catch these. I responded that I would be in for all the bits mentioned. I rec'd a PM later with GB #'s that I missed. I would be easier just to be invoiced once I committed to the buy. Conversely if you send a code, I should be able to go to the web site, punch it in and buy the bits. I put the code in your search bat and crickets. Am I supposed to add all the items to the cart then go coupon code? While I really do appreciate the offers and have participated before, it seems tougher than needs to be to follow the dots. Mike Package for ALL the late side shifter bushings for $20 1 -911.424.139.00 ball cup http://shop.914rubber.com/91142413900-Ball...91142413900.htm 1-914.424.224.02 trans mount bushing http://shop.914rubber.com/Late-side-shifte...91442422402.htm 1-914.424.224.03 firewall bushing http://shop.914rubber.com/91442422403-late...91442422403.htm 1- 91442423902 side shift bellows http://shop.914rubber.com/914-late-side-sh...p3plqscsfapp006 2-911 424 223 03 shift knuckle bushings http://shop.914rubber.com/searchquick-subm...eywords=Knuckle I'll also offer the ability to add the cover and band for another $20 if you add to the GB $40 total) Only catch need 10 takers for a GB. I'll post up a thread. Mark |
Lo-Fi Version | Time is now: 27th December 2024 - 12:48 PM |
