Distributor Problems, Missing on Cylinder #4 |
warrenoliver |
Oct 1 2017, 05:31 PM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
I just returned from a long weekend trip with some other PCA members. The weather was beautiful and we had a great time. My car did not cooperate. I have a 73, 2.0 with FI and Pertronix Ignitor ignition. I have had the Pertronix ignition for a couple of years now and I have had no problems. The problem I am having with the car is that initially it runs great while the engine is cold and while it is warming up. Once it is warmed up - about 7-10 miles, on country roads, it begins missing badly. The miss is not consistent and seems to get better on acceleration. When I come to a stop, the engine idles very slow (200-400 rpm) and sounds like a John Deere tractor.
I put a timing light on each of the spark plug wires and found cylinder #4 is misfiring badly. I thought maybe the wire was bad so I switched it with another cylinder and found that #4 was still missing. I had an old distributor cap and put that on thinking maybe it was a cracked distributor cap. The problem stays with cylinder #4 with both caps. I am now thinking it must be either the rotor or the electronic ignition module. Tomorrow I will try a different rotor. My question is: Does this sound like the electronic module is going bad? When they go bad, do they cause this intermittent miss? Any other ideas out there? Thanks. Warrenoliver |
michael7810 |
Oct 2 2017, 09:13 PM
Senior Member Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Did you replace the rotor?
warrenoliver |
Oct 3 2017, 07:04 PM
Did you replace the rotor? Yes, one of the first things I did along with the distributor cap. I changed the coil today and found a chunk broken out of the insulation of the relay board. I stuffed a towel under the board to keep it from warming up and took it for a drive. I drove about 20 minutes without any engine miss. The last 5 minutes I removed the towel and within minutes, it began to miss. I am now leaning toward the relay board but I need to drive it some more to see if I really have narrowed it down to that. |
Lo-Fi Version | Time is now: 28th December 2024 - 04:27 AM |
