Transaxle oil for 901 With Quaiffe LSD, Just bought one. |
motorvated |
Sep 30 2017, 07:14 PM
Member Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Just bought a 901 transaxle with a Quaiffe LSD in it. Any recommendations for oil type and quantity for it. Don't want to burn it up.
johnhora |
Oct 3 2017, 07:17 PM
Senior Member Group: Members Posts: 874 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Maybe just ask Quaiffe...
From their website: http://quaife.co.uk/customer-service/technical-support/ What sort of gear oil should I use ? When running a Quaife ATB helical gear limited slip Differential in a standard transaxle gearbox, we recommend that you use whatever your vehicle’s manufacturer recommends. The Quaife ATB Differential does not require any special lubricants. When running Quaife gearbox internals and a Quaife ATB differential – we recommend FuchsTitan SYN5 75W90. For a Quaife ATB differential, running in a rear axle – use a hypoid 90 or 75W90, as above. For those applications that will accept a GL5 or SAE75W90 gear oil, we recommend and sell Silkolene SYN5 75W90 gear oil. We use Silkolene in all our own Quaife racing transmissions |
motorvated |
Oct 4 2017, 05:50 AM
Maybe just ask Quaiffe... From their website: http://quaife.co.uk/customer-service/technical-support/ What sort of gear oil should I use ? When running a Quaife ATB helical gear limited slip Differential in a standard transaxle gearbox, we recommend that you use whatever your vehicle’s manufacturer recommends. The Quaife ATB Differential does not require any special lubricants. When running Quaife gearbox internals and a Quaife ATB differential – we recommend FuchsTitan SYN5 75W90. For a Quaife ATB differential, running in a rear axle – use a hypoid 90 or 75W90, as above. For those applications that will accept a GL5 or SAE75W90 gear oil, we recommend and sell Silkolene SYN5 75W90 gear oil. We use Silkolene in all our own Quaife racing transmissions So can the 901 take GL5 or not? Seems to be some confusion over this. |
Steve |
Oct 4 2017, 08:29 AM
914 Guru Group: Members Posts: 5,766 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Maybe just ask Quaiffe... From their website: http://quaife.co.uk/customer-service/technical-support/ What sort of gear oil should I use ? When running a Quaife ATB helical gear limited slip Differential in a standard transaxle gearbox, we recommend that you use whatever your vehicle’s manufacturer recommends. The Quaife ATB Differential does not require any special lubricants. When running Quaife gearbox internals and a Quaife ATB differential – we recommend FuchsTitan SYN5 75W90. For a Quaife ATB differential, running in a rear axle – use a hypoid 90 or 75W90, as above. For those applications that will accept a GL5 or SAE75W90 gear oil, we recommend and sell Silkolene SYN5 75W90 gear oil. We use Silkolene in all our own Quaife racing transmissions The factory manuals state GL-5. The above does not mention Porsche 901/914 or 915 gear boxes So can the 901 take GL5 or not? Seems to be some confusion over this. |
Lo-Fi Version | Time is now: 27th December 2024 - 09:09 AM |
