73 2.0 COA matching, elec defrost, new webers - San Francisco |
moezilla |
Oct 2 2017, 02:53 PM
Newbie Group: Members Posts: 6 Joined: 24-July 09 From: CA Member No.: 10,600 Region Association: None |
Deposit taken sold pending full payment. |
Jazzy |
Oct 5 2017, 10:56 AM
Newbie Group: Members Posts: 32 Joined: 16-September 17 From: The Netherlands Member No.: 21,432 Region Association: Europe |
I realized I could've worded my question better. (IMG:style_emoticons/default/smile.gif) I'm familiar with the costs of a paint job, but I'm not sure what this car requires to fix the rust. Is it just a new panel in the rear trunk?
moezilla |
Oct 5 2017, 11:43 AM
I realized I could've worded my question better. (IMG:style_emoticons/default/smile.gif) I'm familiar with the costs of a paint job, but I'm not sure what this car requires to fix the rust. Is it just a new panel in the rear trunk? The panel is inexpensive, but the labor is very expensive. The Restoration Designs people say 3-4 hours (actually 5 hours) . Your have to cut out half of the panel, and then drill and set tap screws after aligning it the new panel with weldable primer into place, then set the rosette welds. The trick is the rear sway bar mounts as some cars, like this one, have a rear sway bar. Some have cut around those, but normally you would need to re-weld those into the new panel. Otherwise the panel is not so structural. After being welded in and the welds smoothed, primer, and then paint. Out here in Norcal labor like that is between $60 and $120 per hour, or even more if you get one of the top two (we know who they are!) There is a online video on the repair. On this car, there is a small repair weld needed to the rear of the passenger door. It appears to be less than two hours work. The rust on the front fender top is rust bubbling through the paint, where prep was not done properly in the late 80s. This could be ground down and treated with Por15, primer, paint. There are about four other tiny bubble spots smaller than a dime. Normally there would be floor panel section replacement on these cars, but this one has only surface rust. I have normally seen the sills, rockers, jack points, door bottoms rusted at corners but cannot find that condition on this car. There was some hell hole repair in the past. There does not appear to be bondo repair or other indication of accidents. The rear trunk lid does not show yellow, so either it was removed and stripped to yellow, or a different trunk lid was painted for assembly. The gaps around the car look good, and can be seen in the photos. So 4-6 hours welding plus 1-3 hours welding, is what I am guessing. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:57 AM |
