Clutch arm position ?, correct or not... |
porschetub |
Oct 1 2017, 04:55 PM
Advanced Member Group: Members Posts: 4,756 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Based on what I have studied I seem to think this is not right,new pressure plate/disk,new cable,rebuilt pedal assembly etc ,etc and unknown flywheel in good condition,thinking it has been heavily machined,pedal adjustment is by the book...my idea is the lever is hitting the trans case when pedal fully down...help please before I pull the g/box again.
TIA guys. P.S.clutch cable tube is fine. |
johnhora |
Oct 4 2017, 02:44 PM
Senior Member Group: Members Posts: 874 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Dave_Darling |
Oct 6 2017, 02:34 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
here you go...flywheel specs Notice the upper-right corner. These specs are specifically for the 914-6, not the four-cylinder motors. I believe the numbers do work "well enough" for the four-bangers, but the diagram specifically is for the Six. I have never found an official diagram for the four-cylinder flywheel tolerances. --DD |
Lo-Fi Version | Time is now: 28th December 2024 - 02:03 AM |
