How to extend positive battery cable, I need to place battery in trunk temporarily |
914 RZ-1 |
Oct 7 2017, 12:40 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
What is the best/easiest way to make the positive battery cable longer? I do not want to cut it.
I need to temporarily put the battery in the rear trunk. I don't want to cut any cables. I plan to get a longer negative cable assembly but that is not possible with the positive cable. |
porschetub |
Oct 7 2017, 01:42 PM
Advanced Member Group: Members Posts: 4,756 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
What is the best/easiest way to make the positive battery cable longer? I do not want to cut it. I need to temporarily put the battery in the rear trunk. I don't want to cut any cables. I plan to get a longer negative cable assembly but that is not possible with the positive cable. Buy an extension piece, insulate where you bolt it on,you will need a cable that has a post clamp one end and an 8mm eyelet the other,how do you plan the earth the battery negative ?,make sure you fasten the battery down solidly. |
914 RZ-1 |
Oct 7 2017, 04:37 PM
What is the best/easiest way to make the positive battery cable longer? I do not want to cut it. I need to temporarily put the battery in the rear trunk. I don't want to cut any cables. I plan to get a longer negative cable assembly but that is not possible with the positive cable. Buy an extension piece, insulate where you bolt it on,you will need a cable that has a post clamp one end and an 8mm eyelet the other,how do you plan the earth the battery negative ?,make sure you fasten the battery down solidly. Thanks. I'm buying a longer cable assembly for the negative. How would I secure it in the trunk? |
Lo-Fi Version | Time is now: 28th December 2024 - 12:22 AM |
